Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
223 Discussions
SVM: SystemError: Model is not full initialized
Ryo_A_
I am trying to use the pyDAAL SVM to do binary classification, but I keep running into an system error at the prediction compute().
I wrote a small reproducer for the issue I was seeing on my original code:
import numpy as np
from daal.data_management import HomogenNumericTable
from daal.algorithms.svm import training, prediction
from daal.algorithms import kernel_function, classifier
import daal.algorithms.kernel_function.rbf
import daal.algorithms.classifier.training
import daal.algorithms.classifier.prediction
trn_X = HomogenNumericTable(np.random.randn(3000,10))
trn_Y = HomogenNumericTable(np.random.randn(3000,1))
tst_X = HomogenNumericTable(np.random.randn(1000,10))
kernel = kernel_function.rbf.Batch()
trainer = training.Batch()
trainer.parameter.kernel =  kernel
trainer.parameter.C =  1.0
trainer.parameter.gamma = 0.001
trainer.input.set(classifier.training.data,   trn_X)
trainer.input.set(classifier.training.labels, trn_Y)
trn_res = trainer.compute()
predictor = prediction.Batch()
predictor.parameter.kernel = kernel
predictor.input.setTable(classifier.prediction.data,  tst_X)
predictor.input.setModel(classifier.prediction.model, trn_res.get(classifier.training.model))
predictor.compute()
And running this reproducer gives me this error:
Traceback (most recent call last):
  File "svm-reproducer.py", line 27, in <module>
    predictor.compute()
  File "/opt/intel/intelpython_update_3/intelpython2/lib/python2.7/site-packages/daal/algorithms/svm/prediction.py", line 185, in compute
    return _prediction12.Batch_Float64DefaultDense_compute(self)
Details:
Argument name: supportVectors
Is there something else that I am missing? I took a look at the example directory, and the online github examples, but I could not figure out what the step I am missing is. As shown in the error, I am using 2017 update 3 pyDAAL.
Thanks in advance,
Ryo Asai
VictoriyaS_F_Intel
Hello Ryo,
In your example SVM model is not trained due to incorrect values of the class labels.
trn_Y numeric table should contain values {-1, 1} as specified in the DAAL Developer Guide, "Support Vector Machine Classifier > Details":
“Given n feature vectors x 1= (x 11,…,x 1p ), ..., x n = (x n1,…,x np ) of size p and a vector of class labels y = (y 1,…,y n ), where y i ∈ {-1,1} describes the class to which the feature vector x i belongs”.
The library does not check the content input data for validity as scanning the whole numeric tables will affect the performance of the computations.The library’s documentation such as Intel DAAL Developer Guide specifies the requirements to the parameters of the algorithms and their representation.
Ryo_A_
Ah I see. I was able to train the model for both the code snippet and the original code.
Thank you so much for your help!
Ryo
