Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
SVM multi class example
Toyoo
I'm learning oneAPI Data Analytic Libraty .
I can't find any multi class SVM  example under  %ONEAPIPATH%/oneAPI/dal/2021.6.0/examples/oneapi/dpc/.
Only two class is supported on dpc?
Where can I find the specifiction difference of dcp svm and cpp svm?
 Thank you.
AthiraM_Intel
Multi class is supported on dpc also. You can create your own sample to run multiclass. You can refer the multiclass sample available under cpp. (%ONEAPIPATH%/oneAPI/dal/2021.6.0/examples/oneapi/cpp/svm)
Please refer the below documentations for more details about the specifications of oneDAL:
https://github.com/oneapi-src/oneDAL
https://docs.oneapi.io/versions/latest/onedal/onedal/algorithms/svm/index.html
Hope this helps. If you have any issue, please let us know.
AthiraM_Intel
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Toyoo
I'm sorry for late reply.
Thank you for your information. I'll try to write a multi class SVM code on dcp.
Thank you.
