Hi
Sorry for this extreme beginner question but I am having a hard time in setting up a very basic 2D Convolution forward/backward layer in a neural network. All the example codes provided build an explicit forward and backward layer.
Here is my Neural network layer configuration code:
Collection<LayerDescriptor> configureSimpleNet()
Collection<LayerDescriptor> configuration;
SharedPtr<layers::convolution2d::Batch<> > conv2d(new layers::convolution2d::Batch<>);
conv2d->parameter.kernelSize = layers::convolution2d::KernelSize(5,5);
conv2d->parameter.nKernels = 6;
conv2d->parameter.spatialDimensions = layers::convolution2d::SpatialDimensions(32,32);
configuration.push_back(LayerDescriptor(0, conv2d, NextLayers()));
return configuration;
First question: Do I have to set the spatialDimension parameter and if so what does it reflect? Documentation is a bit vague on this.
Basically I assume with that I have 5x5 convolution kernel with 6 different kernels basically output a 28x28x6 tensor from this step, correct?
Well my input feed into the network is a Homogenous Tensor consisting of a 32x32x1 data dimension, here is the code
float* testData = new float[32*32];
float* testData2 = new float[1];
testData2[0] = 1;
for (int j = 0; j < 32; j++)
for (int i = 0; i < 32; i++)
testData[i + j * 32] = float(i) * float(j);
size_t nDim = 3, dims[] = {32,32,1};
size_t dims2[] = {1};
SharedPtr<Tensor> bogusData(new HomogenTensor<float>(nDim, dims, (float*)testData));
SharedPtr<Tensor> bogusData2(new HomogenTensor<float>(1,dims2,(float*)testData2));
And this is how I set up my network
training::Batch<> trainingNet;
Collection<LayerDescriptor> layersConfiguration = configureSimpleNet();
trainingNet.initialize(bogusData->getDimensions(), layersConfiguration);
trainingNet.input.set(training::data, bogusData);
trainingNet.input.set(groundTruth, bogusData2);
trainingNet.parameter.optimizationSolver->parameter.learningRateSequence =
SharedPtr<NumericTable>(new HomogenNumericTable<>(1, 1, NumericTable::doAllocate, 0.001));
trainingNet.parameter.nIterations = 6000;
trainingNet.compute();
It all compiles nicely but when I run it I get this
terminate called after throwing an instance of 'daal::services::interface1::Exception'
what(): Convolution layer internal error
What am I doing wrong?
Hi, Joachim
Thanks for your interest.
At the current moment we did not yet add full support of spatialDimensions parameter.
Currently convolution layer expects 4-d tensor as follows:
size_t nDim = 4, dims[] = {1,1,32,32};
The first dimensions is a batch dimension, the second - channels dimension, the last two dimensions are spatial.
If you compile your code with -DDAAL_CHECK_PARAMETER define, additional checks will be enabled in run-time, which may provide more details in error message.
Ah I see thank you good to know. Yes that resolved the problem and thank you about the compiler switch that might indeed come handy. So I guess if I concatenate n-32x32 input data blocks together in a single Tensor and treat them each as a 32x32 spatial convolution in the NN layer
I would have to change the dims[] = {n,1,32,32}, right?
Yes, that should work
Excellent okay sorry to bombard you with another follow-up noop question.
But what if I attach a maximum_2d_pool layer underneath it, do I need to specify also 4 dimensions in the Batch constructor and then set firstIndex = 2 and secondIndex = 3 in its parameter field member?
Yes, in this case max pooling will be performed for the same spatial dimensions as convolution.
