Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
232 Discussions
Unable to install Intel Python on Windows and Conda
crossxwill
I'm on a Windows computer with an Intel i9 CPU. The following conda commands return an error message:
conda create -n intelpy
conda activate intelpy
conda config --add channels https://software.repos.intel.com/python/conda/
conda install intelpython3_core python=3.9
The error says:
Channels:
- https://software.repos.intel.com/python/conda
- defaults
Platform: win-64
Collecting package metadata (repodata.json): \ ERROR conda.auxlib.logz:stringify(171): Expecting value: line 1 column 1 (char 0)
Traceback (most recent call last):
File "C:\Users\User\miniconda3\lib\site-packages\requests\models.py", line 971, in json
return complexjson.loads(self.text, **kwargs)
File "C:\Users\User\miniconda3\lib\json\__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "C:\Users\User\miniconda3\lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Users\User\miniconda3\lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
During handling of the above exception, another exception occurred:
File "C:\Users\User\miniconda3\lib\site-packages\conda\auxlib\logz.py", line 165, in stringify
requests_models_Response_builder(builder, obj)
File "C:\Users\User\miniconda3\lib\site-packages\conda\auxlib\logz.py", line 141, in requests_models_Response_builder
resp = response_object.json()
File "C:\Users\User\miniconda3\lib\site-packages\requests\models.py", line 975, in json
raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)
requests.exceptions.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
done
Solving environment: failed
LibMambaUnsatisfiableError: Encountered problems while solving:
- nothing provides bzip2 1.0.8 hcfcfb64_5 needed by intelpython3_core-2024.2.0-py310_0
Could not solve for environment specs
The following package could not be installed
└─ intelpython3_core is not installable because it requires
└─ bzip2 1.0.8 hcfcfb64_5, which does not exist (perhaps a missing channel).
