Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Which GNU C/C++ version is required?
joachim_d_
Hi there, as there are two conflicting answers on this, the open source version on GIthub claims
GNU C/C++ 5.1 here (https://github.com/01org/daal)
but in the Getting started guide system requirements on the Intel website (https://software.intel.com/en-us/articles/intel-daal-2016-system-requirements)
it says
GNU C/C++ 4.9
Ilya_B_Intel
Hi, Joachim
If you take pre-built version of the library, you will be able to use it with GCC 4.9+
In order to build library from sources, you will need GCC 5.1+.
Ilya_B_Intel
Hi, Joachim
joachim_d_
Excellent thank you I am using the prebuild-version and it seems to work fine with GCC4.9.2
