Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
cannot import name 'printNumericTable'
yingxing__bao
After I install the pyDAAL according to this tutorial  and this tutorial, when I try to run the example "pca_cor_dense_online.py",I got the error "cannot import name 'printNumericTable'",And this is caused by the code
from utils import printNumericTable
so how can I configure to correct this error?
Preethi_V_Intel
You can find 'utils' in your Anaconda environment folder
~\envs\<anaconda env>\share\pydaal_examples\examples\python\source\utils
There are number of ways you can access this module in your python code. Below are a few
1. Move the utils folder to your current working directory
or
2. Append this folder to the system path in your Python script
import sys
sys.path.append(<'utils' path>)
or
3. Move the utils folder to site-packages folder of your environment.
site-packages can be found here - ~\envs\<anaconda env>\Lib\site-packages
yingxing__bao
Hi
Thank you for your reply.
I have solved the problem according to your method.
I installed the package utils through pip install utils  in the cmd before, so I guess the utils installed through cmd is different from the one you said.
