Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
225 Discussions
just a quick feedback, aiAnalyticsToolkitSamples helloworld seems broken
anttiryt
at page
https://devcloud.intel.com/oneapi/get_started/aiAnalyticsToolkitSamples/
2)
Run a Hello World! Sample
  1. Bash
  2. Create a hello-world.sh script with the following contents for executing the sample:
    #!/bin/bash
    source /opt/intel/inteloneapi/setvars.sh  > /dev/null 2>&1
    source activate tensorflow
    python TensorFlow_HelloWorld.py
    Bash
Run
Jobs submitted in batch mode are placed in a queue waiting for the necessary resources (compute nodes) to become available. The jobs will be executed on a first-come basis on the first available node(s) that have the requested property or label.
  1. Run the sample on a gpu node:
    qsub -l nodes=1:gpu:ppn=2 -d . hello-world.sh
    and the end result
    u182694@login-2:~/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted$ cat hello-world.sh.e2108489
    File "/home/u182694/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted/TensorFlow_HelloWorld.py", line 11, in <module>
    import tensorflow.compat.v1 as tf
    ModuleNotFoundError: No module named 'tensorflow'     <-----
    u182694@login-2:~/oneAPI-samples/AI-and-Analytics/Getting-Started-Samples/IntelTensorFlow_GettingStarted$ cat hello-world.sh.o2108489
    # Date: Wed 28 Dec 2022 11:51:28 AM PST
    # Job ID: 2108489.v-qsvr-1.aidevcloud
    # User: u182694
    # Resources: cput=75:00:00,neednodes=1:gpu:ppn=2,nodes=1:gpu:ppn=2,walltime=06:00:00
    # End of output for job 2108489.v-qsvr-1.aidevcloud
    # Date: Wed 28 Dec 2022 11:51:31 AM PST
    just a side note, the system is mind bogglingly slow and really hard to use. I wish people stopped using NFS/NIS or other shared network infra for user dirs. It was a bad idea 20 years ago, and still is.
VaradJ_Intel
Good day to you
Thanks for reporting this issue. We were able to reproduce it and we have informed the development team about it.
Meanwhile you can follow the below given workaround to move ahead with Hello World Sample.
Before running the hello world sample run the following commands:
conda activate tensorflow
pip install --user tensorflow==2.10.0
And now follow the instructions given to run the hello world sample.
Please do let us know if you still face any issues.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues.
Thank You!
VaradJ_Intel
Good day to you
Thank You!
VaradJ_Intel
Good day to you
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thank You!
