Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
231 Discussions
why daal4py model is 8.02 GB while the same LightGBM model is 426 KB ?
Adarsh2
I am using Intel Devcloud and I have created a lightgbm model for binary classification using this code -
import lightgbm as lgb
bst = lgb.train(params, train_data, num_boost_round=10000, valid_sets=[valid_data], callbacks = [callback])
I read this article which talks about how daal4py make LightGBM inference faster. So, I converted this lightgbm model into daal4py model for inference using this code -
daal_model = d4p.get_gbt_model_from_lightgbm(bst)
After this I tried to save this "daal_model" in my pc using pickle.
import pickle
with open('model.pkl','wb') as out:
    pickle.dump(daal_model, out)
Issue
The model.pkl file is 8.02 GB large. How is this possible? And why is it happening? I tried saving my normal model "bst" using pickle and it is just 426 KB. Why daal4py model is so big?
How to Reproduce -
Huiyan_C_Intel
Hi @Adarsh2,
By design, daal4py trees expect a dense node structure and allocate memory accordingly. The provided example creates extremely sparse trees and is unsuitable for running in daal4py.
We will add support for these scenarios. At the time being, you can run the model with a reasonable maximum depth, for example params['max_depth'] = 8. It provides similar accuracy, and the resulting model dump is only 2.9 MB.
AthiraM_Intel
We have observed the same issue with daal4py (version - 2023.2.1) when running your code in DevCloud for oneAPI.
We are checking on this internally, will get back to you with an update.
Meanwhile can you share the version of daal4py you are using?
Adarsh2
I am using 2023.1.1
d4p._get__version__()
>> '(2023, 1, 1, \'"P"\')'
Huiyan_C_Intel
Thanks for reporting this issue, we are looking into it.
Huiyan_C_Intel
Hi @Adarsh2,
OlivierMeslin
Thanks @Huiyan_C_Intel for the precise answer, that was exactly the issue I was trying to solve!
