Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
583 Discussions
Behaviour of multi queues on single device.
shenuo
What's the execution order  of multi queues on 1 same device?
let's say
    gpu_selector gs;
    queue Q1(gs);
    queue Q2(gs);
    queue Q3(gs);
    Q1.submmit(/***/);
   Q2.submmit(/***/);
   Q3.submmit(/***/);
 are they executed 1 by 1, or it's determined by the runtime, the order is uncertain, even concurrent?
HemanthCH_Intel
When we create multiple queues for the same device then the execution is in a serial manner(one after the other). When we create multiple contexts and multiple queues then the execution is concurrent.
Thanks & Regards,
Hemanth
shenuo
I'm sorry ,still a little confused.
 is that mean different device has different context?
can you give me a example to illustrate how to create concurrent queues on same device?
thanks !
HemanthCH_Intel
You can refer to the sample vector add program where we created multiple contexts and multiple queues to run concurrently on a single device.
Thanks & Regards,
Hemanth.
HemanthCH_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Hemanth
HemanthCH_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
