I have installed oneAPI at my system with Ubuntu 18.04 LTS, Intel® Xeon(R) CPU E5-1620 v4 @ 3.50GHz × 8, Quadro P4000/PCIe/SSE2, gcc/g++5.4.
When I make all, the errors are
dpcpp -o vector-add.exe src/vector-add.cpp -lOpenCL -lsycl
/opt/intel/inteloneapi/compiler/2021.1-beta03/linux/bin/../lib/libsycl.so: undefined reference to `clCreateProgramWithIL@OPENCL_2.1'
/opt/intel/inteloneapi/compiler/2021.1-beta03/linux/bin/../lib/libsycl.so: undefined reference to `clGetKernelSubGroupInfo@OPENCL_2.1'
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
Makefile:10: recipe for target 'main' failed
make: *** [main] Error 1
What could be wrong?
- Tags:
- General Support
Hi, You may also need to uninstall the Intel OpenCL runtime from the Ubuntu repository (package ocl-icd-libopencl1). The one that comes with the basekit is more recent even compared to the latest Ububtu (19.10). You can check which library is used by running > ldd /opt/intel/inteloneapi/compiler/latest/linux/lib/libsycl.so | grep OpenCL If you did not run > source /opt/intel/inteloneapi/setvars.sh it may point to /usr/lib/x86_64-linux-gnu/libOpenCL.so.1 or some other library and /opt/intel/inteloneapi/compiler/latest/linux/lib/libOpenCL.so.1 otherwise. You can check the supported version and symbols by running > nm -gD libOpenCL.so.1 | grep 'OPENCL\|clGetKernelSubGroupInfo' on each of the found libraries. -Dmitry
Hi Naing,
We are working on this issue and will get back to you.
Kaleem
This error is due to conflicting libOpenCL.so, I will suggest you to properly uninstall everything and re-install beta03 base toolkit and then it will work.
-Abhishek
Thanks a lot.
Let us know if it worked for you and get back to us if you faced any issue.
-Abhishek
The old installation was removed and reinstall new one following the instructions in the link.
But still have the same error when I make all.
coie@coie-HP-Z440-Workstation:~/Data/coie/Softwares/oneAPI/dpc++/module04/Lab_module4/devcon/complex_mult$ make all
dpcpp lab/complex_mult.cpp -o bin/complex_mult -Isrc/ -lOpenCL -lsycl
Makefile:13: recipe for target 'main' failed
Following one of the suggestions above to check opencl and output is as follow.
coie@coie-HP-Z440-Workstation:~/Data/coie/Softwares/oneAPI/dpc++/module04/Lab_module4/devcon/complex_mult$ ldd /opt/intel/inteloneapi/compiler/latest/linux/lib/
libOpenCL.so.1 => /opt/intel/inteloneapi/compiler/latest/linux/lib/libOpenCL.so.1 (0x00007feb9bdde000)
Why I still can't compile the project?
What does
nm -gD /opt/intel/inteloneapi/compiler/latest/linux/lib/libOpenCL.so.1 | grep 'OPENCL\|clGetKernelSubGroupInfo\|clCreateProgramWithIL'
show you?
-Dmitry
UPD: In the DevCloud the command does not work, had to do in two steps: nm -gD /opt/intel/inteloneapi/compiler/latest/linux/lib/libOpenCL.so.1> out grep 'OPENCL\|clGetKernelSubGroupInfo\|clCreateProgramWithIL' out
Yes this command "dpcpp -o vector-add.exe src/vector-add.cpp" can build exe file. Thanks.
make all doesn't work.
This command
gave
00000000000046f0 T clCreateProgramWithIL
0000000000004720 T clGetKernelSubGroupInfo
0000000000000000 A OPENCL_1.0
0000000000000000 A OPENCL_1.1
0000000000000000 A OPENCL_1.2
0000000000000000 A OPENCL_2.0
0000000000000000 A OPENCL_2.1
0000000000000000 A OPENCL_2.2
naing,
Try change ./src/CMakeLists.txt:target_link_libraries(complex_mult OpenCL sycl)
to ./src/CMakeLists.txt:target_link_libraries(complex_mult sycl)
I found same issue on HPCKit-code-samples..
Hi Naing,
Let us know if we can close this thread, you are always welcome to raise a new thread.
-Abhishek
Yes please go ahead. Removing opencl flag in makefile solved the issue.
Hi Naing,
Hope your issue is resolved. We are closing this thread. You can always reach out to us for other queries in a new thread.
Sushma.
