Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
417 Discussions
Cross-platform heterogeneous parallel programming in C++
Aditya_K_5
I read that Intel will be promoting SyCL (otherwise called DPC++, I think) for heterogeneous parallel C++ programming. Is it available on DevCloud, and if so, how do I use it? If not, what's the recommended way to write scientific computing applications that will run on today's and upcoming Intel CPUs and GPUs?
AnubhavJ_intel
Hi Aditya,
Yes, DPC++ is available on DevCloud as part of oneAPI Toolkit.  The following link provides detail for how to use on DevCloud:
https://software.intel.com/en-us/articles/getting-started-with-intel-devcloud-for-oneapi-projects
AnubhavJ_intel
Hi Aditya,
Could you please let us know if the solution provided helped? If there is no response within 2 business days, we will assume that your support request is resolved.
