Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
DCP++ subgroup
RitaChu
What is the difference between subgroup shuffle and group_broadcast.  To me they seem to generate same results if you give the same index to shuffle/broadcast.
SantoshY_Intel
The sub-group broadcast function can be thought of as a specialized version of the general-purpose shuffle function, where the shuffle index is the same for all work-items in the sub-group.
>>"To me they seem to generate same results if you give the same index to shuffle/broadcast."
When the shuffle index is known to be the same for all work-items in the sub-group, then we will get the same results for both shuffle and broadcast.
But, using broadcast instead of shuffle provides the compiler additional information and may increase performance on some implementations.
Thanks & Regards,
Santosh
RitaChu
SantoshY_Intel
Could you please let us know whether you have any other issues? If not, could you please confirm whether we can close this thread from our end?
Thanks & Regards,
Santosh
RitaChu
@SantoshY_Intel I have no more issue, please close the thread.  Thank you very much
SantoshY_Intel
As your issue is resolved, we are closing this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
