When compiling the following byte swap (with x a 64 bit unsigned):
((x & 0xff00000000000000ULL) >> 56)
| ((x & 0x00ff000000000000ULL) >> 40)
| ((x & 0x0000ff0000000000ULL) >> 24)
| ((x & 0x000000ff00000000ULL) >> 8)
| ((x & 0x0000000000ff0000ULL) << 24)
| ((x & 0x000000000000ff00ULL) << 40)
| ((x & 0x00000000000000ffULL) << 56);
DPCPP (llvm-spirv) fails with:
InvalidFunctionCall: Unexpected llvm intrinsic:
llvm.bswap.i64
The version of DPCPP is 2022.0.0 (2022.0.0.20211123). It happens when compiling SYCL kernels for spir64 as well as when I use AOT.
The upstream version of the open source oneAPI compiles the code fine.
To use Intel(R) oneAPI you can "defeat" the optimiser by replacing the `|` by `+` (which is still correct as the bits do not overlap) and it compiles (but is not optimal haha) .
Best,
Michel
Thank you for reporting this problem to us. This is a known issue and will be fixed in the next update.
Can we close this thread for now?
Regards.
Could you please provide the sample reproducer code and steps to reproduce the issue at our end?
Thanks & Regards,
Hemanth.
You may compile the following:
#include <CL/sycl.hpp>
static inline uint64_t bswap(uint64_t x){
return
| ((x & 0x000000ff00000000ULL) >> 8 )
int main(){
sycl::queue q{};
auto ptr = sycl::malloc_device<uint64_t>(1, q);
q.single_task([=](){
*ptr = bswap(*ptr);
}).wait();
With the flags `dpcpp -fsycl -O3`. On Intel(R) DevCloud it crashes with the error I mentioned previously too.
Michel
We are able to able to reproduce your issue at our end and working on this internally. We will get back to you soon.
Thanks & Regards,
Hemanth.
Regards.
Thanks for accepting this as a solution. This thread is now closed and won't be monitored by Intel. If you need anything else, please create a new thread.
Okay, thanks for looking into this and have a nice day!
Best,
