Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
DPCPP source build integration with oneapi
Jonas5
Is it possible to generate envirnoment scripts for custom builds of dpcpp, similar to the default /opt/intel/oneapi/setvars.sh?
SantoshY_Intel
To integrate Intel OneAPI's DPCPP compiler to VSCode, we can use setvars.sh/vars.sh provided in the installation directory.
But, we can see that you are trying to integrate opensource version of DPCPP. So, we suggest you to raise an issue in the below link as we only support Intel oneAPI products in this community.
Link: https://github.com/oneapi-src/oneAPI-samples/issues
Thanks & Regards,
Santosh
Soumya_M_Intel
Hi Jonas,
Thanks for posting your concern on the forum. Since your query is related to the Intel® oneAPI Data Parallel C++, we are moving this topic to the correct community for further assistance.
Have a nice day ahead.
Soumya
SantoshY_Intel
We can use the below command to initialize the compiler environment:
source /opt/intel/oneapi/compiler/2023.0.0/env/vars.sh
Example:
Please let us know if your issue is resolved. If not, then could you please let us know your use case & elaborate your problem statement?
Thanks & Regards,
Santosh
Jonas5
Thanks for the reply.
I have a source build located in ~/sycl_workspace following this guide
but I'm not able to configure environment variables for this build.
Is it possible to merge this build into the existing installation of OneAPI, so that I get something like:
/opt/intel/oneapi/custom_env.sh
/opt/intel/oneapi/compiler/CustomCompiler/linux/IntelDPCPP/IntelDPCPPConfig.cmake
To elaborate, I'm having a hard time integrating my dpcpp source build with my Vscode Cmake-project.
It would be nice to have the option of using custom builds with environment configurator .
SantoshY_Intel
Thanks & Regards,
Santosh
SantoshY_Intel
We are closing this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
