Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
444 Discussions
How to call class function inside a parallel_for having queue as a parameter
Anitha
I tried this
q.parallel_for(nd_range<1>((16), (16)), [=](nd_item<1> item)
{    auto index = item.get_global_id(0);
      classA.func(a[index], q);
void classA::func(float *a, queue & my_queue)
But got this error
Kernel parameter has non_trivially copy constructible class/struct type 'sycl::queue'
VarshaS_Intel
Could you please provide us with the OS details and the version of dpcpp you are using?
Could you please provide us with a complete sample reproducer code to investigate more at our end?
Thanks & Regards,
Varsha
Anitha
OS details:
OS - Redhat enterprise Linux 8.0
Processor - Intel Xeon(R) 16 - COMPUTE UNITS
OS type - 64-bit
ToolKit versions:
Basekit version - 2021.2.0-2883
Hpckit version - 2021.2.0-2997
Dpcpp compiler version - 2021.2.0-610
Code has been attached.
Thanks & Regards,
Anitha
VarshaS_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Varsha
VarshaS_Intel
Could you please let us know the use case of passing the queue as a parameter and calling it inside a kernel?
In your code(fft.cpp) you are submitting a queue inside the function definition which is being called inside a kernel. So, indirectly it became a recursive call. Recursion is not supported by the SYCL.
And also, if you want to use FFT with SYCL kernels please find the path where you can find the samples for it in C:\Program Files (x86)\Intel\oneAPI\mkl\latest\examples\examples_dpcpp.zip\dpcpp\dft\source
Thanks & Regards,
Varsha
Anitha
Here we are trying to do fft 16 times for different set of input's using for loop.
To get better execution time we thought of making it parallel we used parallel_for and passed queue as a parameter which is required by a fft.
Thanks and Regards,
Anitha
VarshaS_Intel
Could you please try the samples if you want to use FFT with SYCL kernels please find the path where you can find the samples for it in C:\Program Files (x86)\Intel\oneAPI\mkl\latest\examples\examples_dpcpp.zip\dpcpp\dft\source
Could you please let us know what commands are you using at the time of compilation of your code? And also, could you please provide the complete error log?
Thanks & Regards,
Varsha
VarshaS_Intel
Could you please provide us with the steps/command you have followed ?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
Anitha
We are using eclipse to build the program.
Command : dpcpp
All options : -g -Wall -O0 -l /parallelFor
And using terminal to run.
./parallelFor
But while building itself we are getting error.
Thanks & Regards,
Anitha
