I am porting some cuda code and it uses cuda functions:
- cuGraphicsMapResources
- cuGraphicsResourceGetMappedPointer
- cuGraphicsGLRegisterBuffer
- cuGraphicsUnregisterResource and
- cuGraphicsUnmapResources
As per my understanding of the code, these functions are allowing cuda code to interact with OpenGL buffers. I understand that there is no direct interoperability between OneAPI and OpenGL and it has to be done through OpenCL interop.
Can you please suggest which functions can I use instead of cuda functions mentioned above?
Gagan
That's correct, there's no direct interoperability between oneAPI and OpenGL currently. You may refer to the tutorial on OpenCL and OpenGL interoperability in the link below:
DPCT subject matter experts will get in touch with you shortly regarding equivalent DPCPP functions.
Rahul
The following articles can help with the DPC++,OpenCL and OpenGL interop.
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
