Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
580 Discussions
Intel C++ Compiler complains on multiple definitions
Alvaro_Palma_Aste
I'm trying to compile a software using ICPX, Intel(R) oneAPI DPC++/C++ Compiler 2023.0.0 (2023.0.0.20221201).
ICPX seems to have some symbols redefined v/s an external library I'm using (over which I don't have control hence can't change), so, to avoid the issues, I'm attempting to add -Wl,-z,muldefs or -z muldefs as options to the ICPX command line. However, when doing so, ICPX complains in both cases:
icpx: fatal error: -z muldefs: 'linker' input unused [-Wunused-command-line-argument]
(I've also turned -Wfatal-errors on my project).
So, my question is: How would then be the proper way to pass arguments to the linker?
Thanks in advance.
ShivaniK_Intel
Thanks for posting in the Intel forums.
Could you please provide us with the sample reproducer code and steps to reproduce the issue at our end?
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you, could you please provide us with the details asked in my previous post?
Thanks & Regards
Shivani
ShivaniK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance please post a new question.
Thanks & Regards
Shivani
