Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
443 Discussions
Problem about image(as a buffer) size and media_block_load/store
tanzl_ustc
Hello,intel engineers.
Recently I met a problem about image size.As you will see in image below,I wrote a simple code for you to understand my problem.when SIZE=64,128 even 2048,it works well.As the size gets larger, problems arise.
I was wondering if it is due to the size limitation of image.Could you please give me some possible reasons of this problem,thanks~.I have attach this code(acc_test.cpp) in my zip file.
Besides,I really need a very large image because recently I am rewriting a CM kernel code(gemm_genx.cpp,attached in the zip file) to its DPC++ ESIMD version.The CM kernel code is about large-scale gemm.At first I wrote a code(gemm_genx_dpcpp.cpp in attached zip file) using share_pointer to transport data between host and device,but I found that the algorithm requires 2D read/write.However media_block_load  and media_block_store requires accessor instead of pointer,so I chose to use block_load/store.Through coordinate conversion, one-dimensional reading replaces two-dimensional reading.After testing, the DPC++ code performance is very poor.After that I used vtune to get an analysis of the DPC++ code, and I found that heavy address computation and memory access operation could be the bottleneck of my DPC++ code.Now I have to use media_block_load and media_block_store.Could you please tell me how to properly use media_block_load/store,thank you very much!
tanzl_ustc
Besides,I have tried to write a code using buffer/accessor to transport data between host and device.I have already found that the problem of my new code could be the size of image I mentioned above.I was wondering if you could take a look on my code to see if there are some other problems exist.I really lack experience in using media_block_load/store, and it is difficult to find suitable examples to learn on the Internet.Thank you very much,the file has already been attached.
tanzl_ustc
Some codes are generated from my code generator so the variable name seems to be meaningless, please take gemm_genx_dpcpp.cpp as a reference,thanks!
NoorjahanSk_Intel
>>Could you please give me some possible reasons of this problem?
If you change your code to below code then it will work without any errors.
#include <CL/sycl.hpp>
#include<iostream>
using namespace sycl;
using namespace std;
const long int SIZE = 2048*(2048/4);
int main() {
  sycl::float4 *b = new sycl::float4[SIZE];
  for (int i = 0; i<SIZE; ++i) {
    b[i] = (float)-i;
    image<2>  b_device(b,image_channel_order::rgba,
                       image_channel_type::fp32, range<2>(2048, 512));
  delete[] b;
  return 0;
If you want to use the initial code then you can increase the stack size using the below command and can run your program without any errors.
ulimit -s 65536
Here, we increase the stack size to 64MB as the default stack size is limited by 10MB.
Could you please let us know how did you analyze the performance of the dpc++ code(steps if any)?
Could you please let us know on what factors you are stating that dpc++ performance is poor?
Also please provide us with the command that you have used to run the CM kernel code
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We have not heard back from you, so we will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
