Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
583 Discussions
Request for Intel OpenCL Offline Compiler (OCLOC)
Viet-Duc
I am trying to perform ahead of time compilation following the instruction here:
https://software.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compilation/ahead-of-time-compilation.html
https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/install-opencl-offline-compiler-ocloc.html
Using the following compiler options:
dpcpp -fsycl-targets=spir64_gen-unknown-unknown-sycldevice -Xs "-device Gen9,dg1,Gen12HP" vector-add.cpp.
The error message is:
dpcpp: error: unable to execute command: Executable "ocloc" doesn't exist!
As I understand, the NDA queue is not configured to accept interactive job (qsub -I).
If I compile on login node and run on Xe_HP, the performance is not as good as expected. For instance, the result of memory bandwidth measurement is aproximately 40% of theoretical maximum of 800GB/s.
Would you make ocloc available system-wide ? If not, is there a way to install it locally ?
Regards.
Jie_L_Intel
The devcloud does not install the ocloc right now. You could try it following the installation guide if you have your own develop machine that could install oneAPI.
https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/install-opencl-offline-compiler-ocloc.html
Gopika_Intel
Thank you for reaching out. We are checking this internally. We will get back to you as soon as we get an update.
Gopika
Viet-Duc
Thanks for moving the post to the suitable forum.
I am not sure if I can show performance of NDA hardware here. Nevertheless, I need to make my case.
The measurement is done using BabelStream, which is a extension of Stream benchmark for heterogenous platforms.
The triad kernel implemented in SYCL is as follow:
template <class T>
void SYCLStream<T>::triad()
  const T scalar = startScalar;
  queue->submit([&](handler &cgh)
    auto ka = d_a->template get_access<access::mode::write>(cgh);
    auto kb = d_b->template get_access<access::mode::read>(cgh);
    auto kc = d_c->template get_access<access::mode::read>(cgh);
    cgh.parallel_for<triad_kernel>(range<1>{array_size}, [=](id<1> idx)
      ka[idx] = kb[idx] + scalar * kc[idx];
  queue->wait();
This implementation does not use USM and work group size is determined by OpenCL runtime, which may affect performance.
Result for DG1 is below:
Array size: 268.4 MB (=0.3 GB)
Total size: 805.3 MB (=0.8 GB)
Using SYCL device Intel(R) Iris(R) Xe MAX Graphics [0x4905]
Driver: 21.11.19310
Function    MBytes/sec  Min (sec)   Max         Average
Triad       59800.403   0.01347     0.01361     0.01354
This translates to 86% of theoretical bandwidth.
Result for Xe_HP is below:
Using SYCL device Intel(R) Graphics [0x0205]
Driver: 21.12.019357+embargo458
Triad       282888.513  0.00285     0.00368     0.00345
This translates to only 36% of the theoretical bandwidth. Tuning workgroup size may give 10% margin gain.
Thus, I am trying to use AOT compilation since the NDA queue does not accept iteractive jobs.
Your insights on this issue is much appreciated.
Jie_L_Intel
