Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
583 Discussions
Runtime evaluation of maximum concurrency in DPC++
danielarndt
Is there any way to get the maximum number of concurrently active threads at runtime (or at least an upper limit)?
AFAICT, I can only ask for the maximum number of compute units and the maximum workgroup size. Is it safe to assume that there is not more than one workgroup active for every compute unit?
RahulV_intel
We are working on your query and will get back to you at the earliest.
Rahul
danielarndt
Calculating an upper limit of concurrent thread numbers at runtime would be good enough for me. How would I do that?
Basically, I am looking for something corresponding to cudaDevAttrMaxThreadsPerMultiProcessor.
