Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
561 Discussions
The dimension and read problem when using DPC++ image arrays
shenuo
This problem really confuse me. I wanna use DPC++ to read a group of images, so the sycl::image was used ,below are my code.
#define N 4   //dimensin
#define M 128 //dimension
#define C 4   //4 channel
#define L 2   // 2 images
int * host_array3_2 = malloc_host<int>(N*M*C*L, Q);
image im3(host_array3_2, image_channel_order::rgba, image_channel_type::unsigned_int32, range{ M,N,L}); //the image format
The kernel code are as follows, I use accessor with image_array tags to  read the data:
Q.submit([&](handler &h) {
           auto out = sycl::stream(1024, 1024 * 2, h);
            accessor<int4, 2, access::mode::read, access::target::image_array> acs3(im3, h);//the accessor format
            h.parallel_for(nd_range{ range{ M ,N,L }, range{ N,N,L } }, [=](nd_item<3> it) {
            int idx = it.get_global_linear_id();
                if (idx == 0){
            confuse here:  out << acs3.get_count() << " " << acs3.get_range() << " \n";
                //const auto &ss = acs3[0];    no compile error
        confuse here:  //ss.read(int2(0, 1));         compiler error: "array subscript out of range"  "SYCL kernel cannot call a variadic function"}
In addition to the read problem , I found that the range is{128,4,4},why the third dimension is 4? Isn’t the value of L(2)? And it seems that the third dimension is only depend on the second dimension, no matter what the L is. Can anybody answer me?
VidyalathaB_Intel
Could you please let us know your environment details on which you are compiling your source code.
OS & version
Compiler & Version
Vidya.
shenuo
Hello, thanks for your reply, my  compiler is oneAPI DPC++ Compiler  (2021.3.0) on windows 10, VS2017. and by the way ,release compile mode is ok
VidyalathaB_Intel
Thanks for providing the details.
The issue is reproducible from our end in Debug mode and in release mode it is working fine.
We are looking into this issue internally. we will get back to you soon.
Vidya.
Alex_Y_Intel
We are still working on your issue internally and we will get back to you with update.
shenuo
Alex_Y_Intel
The issue regarding to last of the 3 numbers in a range that should reflect the quantity of the given 2D images has been fixed. However we're still working on the problem with accessor::read function. We'll come back with update.
