Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
561 Discussions
Use h.parallel_ After for replaces the for loop, the running time increases.
HYB
Use h.parallel_ After for replaces the for loop, the running time increases. How to solve it?How to effectively reduce running time?
AthiraM_Intel
Could you please elaborate more about the issue? Which application you are using?
This forum primarily support queries related to issues with oneAPI DevCloud . Could you please let us know whether your issue is related to oneAPI DevCLoud?
HYB
NoorjahanSk_Intel
Could you please provide the complete reproducer if possible and below environment details
OS & version
Compiler version
Thanks & Regards
Noorjahan.
NoorjahanSk_Intel
 Could you please provide the above-requested details? so that it will help us to investigate more on your issue.
Thanks & Regards
Noorjahan.
NoorjahanSk_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Noorjahan.
