Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
dpcpp -fsanitize=memory/address
flawkjoe
I am trying to look for loose memory allocations in my program using the built in memory sanitizers. Unfortunately the dpcpp compiler does not accept any variation of '-fsanitize=xyz' and reports it as an unknown argument. Does anyone know how to directly set these for the clang compilation units (not the sycl kernels)?
Thank you!
Joe
flawkjoe
I appreciate the reply, however the core of my issue is the inability to pass -fsanitize=xyz into the dpcpp command line. I can easily use clang or gcc and these arguments work fine, but dpcpp does not handle or forward them to the clang compiler as it should.
I also found that valgrind fails due to unknown instructions being added by the sycl compiler, presumably. I tried compiling/using the latest valgrind from git and the error persists.
I am looking into utilizing https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/compiler-options/compiler-option-details/offload-openmp-and-parallel-processing-options/fsycl-host-compiler-options.html but the problem is that it does not keep my C++ arguments. I will have to play around with CMake to see if I can get a reasonably good working solution for this.
VarshaS_Intel
Regarding this, we have reported this issue to the concerned development team. They are looking into your issue. We will update you once the issue is fixed.
Thanks & Regards,
Varsha
flawkjoe
Any updates on this? Thank you!
Joe
FantasticMrFox
Is there an update on this? Is there any way to do memory access and address sanitization in the sycl kernels as well?
Devorah_H_Intel
The fix will be available in the next oneAPI release.
baranovsky
Could you kindly tell us when the next release is planned?
