Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
443 Discussions
isfinite() call is ambiguous on Windows DPC++
AJIOB
Hello
I'm using Intel oneAPI 2022.1.3 (w_BaseKit_p_2022.1.3.210_offline) with VisualStudio 2022 17.0.7 LTS on Windows 10 21H1 Pro x64 English.
I generated vector-add sample & it compiles successfully.
I added that 2 rows for getting finite detection on constant vector in file vector-add-buffers.cpp:
vec<float, 3> test_finite(0.1f, 0.2f, 0.3f);
auto is_finite_vec = isfinite(test_finite);
That code was added in h.parallel_for section (lines 85-88 in file vector-add-buffers.cpp).
Nothing else was changed.
But in compiling time I received an error: call to 'isfinite' is ambiguous
Example project & full logs were attached (from VisualStudio command-line & from usual Windows CMD).
How can I fix that?
With regards,
Alex
P.S. Linux DPC++ compiler (Ubuntu 20.04) works correctly & successfully compiled that code. Compiler's version:
$ dpcpp --version
Intel(R) oneAPI DPC++/C++ Compiler 2022.0.0 (2022.0.0.20211123)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2022.0.2/linux/bin-llvm
NoorjahanSk_Intel
Could you please try changing the line
vec<int, 3> is_finite_vec = isfinite(test_finite);
to
vec<int, 3> is_finite_vec = sycl::isfinite(test_finite);
so that isfinite will de defined from sycl scope.
Hope the provided information helps in resolving your issue.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
to
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thank you for accepting our solution
As this issue has been resolved, we will no longer respond to this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan
