Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
pi_opencl.dll
ZHOU__XK
I have a problem and need help:
Unable to locate the program input point clGetKernelSubGrouplnfo in the dynamic link library C: \ ........ \ bin \ pi_opencl.dll
RahulV_intel
Could you send us the exact error screenshot and tell us the need for pi_opencl.dll?
Also, let us know about your oneapi-basetoolkit version number and OS that you are working on.
--Rahul
ZHOU__XK
我的oneapi-basetoolkit版本号是w_BaseKit_b_2021.1.6.1113,我使用Windows操作系统。屏幕快照如下(汉字翻译为:无法在动态链接库C:\ ......中找到程序输入点clGetKernelSubGrouplnfo。
RahulV_intel
I have translated your question via Google Translate and here is what resulted. Is this the question you were intending to ask?
My oneapi-basetoolkit version number is w_BaseKit_b_2021.1.6.1113, I use the Windows operating system. The screen shot is as follows (Chinese characters are translated as: The program input point clGetKernelSubGrouplnfo cannot be found in the dynamic link library C: \ ......)
If this is your question, follow these steps:
Check your system requirements here for Windows in this link below:
https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-dpcpp-system-requirements-beta.html
If you satisfy the above system requirements,
Kindly look into section no.4 of Known issues and Workarounds(Windows support) and follow these steps:
https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-toolkit-release-notes.html#inpage-nav-4
To run a sample code on Windows(Visual Studio), follow this link:
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-base-windows/top/run-a-sample-project-using-an-ide.html
Let us know if it helps.
--Rahul
RahulV_intel
Let us know if your issue is resolved.
--Rahul
RahulV_intel
As per the process, we are closing this thread, assuming that the solution provided has helped. Feel free to post a new thread if the issue persists.
