Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel® DPC++ Compatibility Tool, and GDB*
443 Discussions
std::isfinite(INFINITY) returns true on Linux
AJIOB
Hello
I'm using Intel oneAPI 2022.1.3 from APT on Ubuntu 20.04 LTS x64 English (Linux-based).
I got example code of std::isfinite() from cppreference, compile them with DPC++ 2022.0.0.20211123 and it works incorrectly on Linux: not as C++ standard wants.
Linux build & execution log was attached.
Linux output:
isfinite(NaN) = true
isfinite(Inf) = true
isfinite(0.0) = true
isfinite(exp(800)) = true
isfinite(DBL_MIN/2.0) = true
Windows version of DPC++ generates correct output:
isfinite(NaN) = false
isfinite(Inf) = false
isfinite(exp(800)) = false
Example code was attached as a test.cpp file in test.zip too.
Code was compiled with command dpcpp test.cpp -o test
How can I fix that behavior?
With regards,
Alex
NoorjahanSk_Intel
Could you please try with below command as it worked (as expected) from our end.
dpcpp test.cpp -fp-model=precise -o test
Please find the below screenshot for more details.
"-fp-model=precise" disables the optimization for floating-point calculations, so that the result won't be changed.
Please refer to below link for more details.
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/compiler-options/compiler-option-details/floating-point-options/fp-model-fp.html
Thanks & regards,
Noorjahan.
AJIOB
Hi Noorjahan,
Yes, you are right, that flag was helpful for fixing behavior on Linux.
But I need to have maximum speed for Linux & Windows with equal & correct behaviour.
What about fixing an optimized version?
With regards,
Alex
VinInn
I advice to test this version [1] as the original has the risk that everything is computed at compile time (try in godbolt for instance)
with Ofast (aka finite-math) one DOES expect isfinite(NAN) to be true
with latest gcc I get
c++ -O3 isfinite.cpp; ./a.out
x = 0
isfinite(0.f/x) = false
isfinite(1.f/x) = false
isfinite(x) = true
isfinite(exp(x)) = true
isfinite(DBL_MIN/x) = false
c++ -Ofast isfinite.cpp
 ./a.out
x = 0
isfinite(0.f/x) = true
isfinite(1.f/x) = true
isfinite(x) = true
isfinite(DBL_MIN/x) = true
[1]
#include <iostream>
#include <cmath>
#include <cfloat>
int main(int argc, char**)
float x = 1.f -float(argc);
std::cout << std::boolalpha
<< "isfinite(NaN) = " << std::isfinite(NAN) << '\n'
<< "isfinite(Inf) = " << std::isfinite(INFINITY) << '\n'
<< "isfinite(0.0) = " << std::isfinite(0.0) << '\n'
<< "isfinite(exp(800)) = " << std::isfinite(std::exp(800)) << '\n'
<< "isfinite(DBL_MIN/2.0) = " << std::isfinite(DBL_MIN/2.0) << '\n';
<< "x = " << x << '\n'
<< "isfinite(0.f/x) = " << std::isfinite(0.f/x) << '\n'
<< "isfinite(1.f/x) = " << std::isfinite(1.f/x) << '\n'
<< "isfinite(x) = " << std::isfinite(0.0) << '\n'
<< "isfinite(exp(x)) = " << std::isfinite(std::exp(x)) << '\n'
<< "isfinite(DBL_MIN/x) = " << std::isfinite(DBL_MIN/x) << '\n';
NoorjahanSk_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Noorjahan
DMITRY_T_Intel
Hi Alex,
I escalated this issue to development. I will update it as soon as I get any information.
Thanks!
DMITRY_T_Intel
Hi Alex,
I got reply from developers:
"Use of dpcpp or icpx uses Intel defaults, which includes -fp-model=fast. This behavior is expected."
Thanks!
