Intel® oneAPI Data Parallel C++
Support for Intel® oneAPI DPC++ Compiler, Intel® oneAPI DPC++ Library, Intel ICX Compiler , Intel® DPC++ Compatibility Tool, and GDB*
sys/stat.h missing
InvisibleWonder
I'm building with dpcpp -std=c++17 and -fsycl, but I don't see stat.h anywhere in the oneapi.  I imagine frankenbuilding it from another glibc version will cause more problems than solve it.  I do however, see stat.h in one of the fpga's implementations...  why is it missing in the base API, then?
What is the best method of dealing with missing components of oneAPI's glibc?
InvisibleWonder
I prepared a minimal test case, but it compiled fine.  This narrowed down the search space enough to find the culprit:
link time optimization isn't supported (-flto).  Without it, the project is now linking properly with dpcpp.
Thank you for your Socratic help
NoorjahanSk_Intel
Hi Gabriel
  As you can see it here https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-dpcpp-system-requirements.html
GNU is a software requirement for oneAPI.
   oneAPI takes glibc from GNU in linux to include C/C++ standard libraries in device code and having gcc is a mandate for using oneAPI for the same reason.
  In addition to this you can also find an extension where you can make use of glibc.
  Please refer: https://software.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/optimization-and-programming-guide/extensions/c-and-c-standard-libraries-support.html
Thanks & Regards
Noorjahan.
InvisibleWonder
Thank you, Noorjahan, but on the devcloud environment, I cannot find libsysl-glibc.o.  Instead, I find:
  /opt/intel/inteloneapi/compiler/2021.2.0/linux/lib/libomp-glibc.o
But when I try to link with that or gcc's default glibc, dpgpp errors out, saying it's incompatible with -fsycl.
Finally, the supported functions in libsysl-glibc are very limited.  Obviously, device code cannot support all the functionality of glibc, but what is host code supposed to do?  How can legacy host code be preserved, while adding sycl functionality in specific offloads?
NoorjahanSk_Intel
>>when I try to link with that or gcc's default glibc, dpcpp errors out, saying it's incompatible with -fsycl
Could you please provide a sample reproducer and steps you have followed. So that, we can work on it from our end.
Thanks & Regards
Noorjahan.
InvisibleWonder
NoorjahanSk_Intel
Glad to know that your issue is resolved.
we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Thanks & Regards
Noorjahan
