Community
cancel
Showing results for
Search instead for
Did you mean:
Hunold__Sascha
API for I_MPI_ADJUST Family
I would like to know whether the Intel MPI Library also has an API to select the algorithm for a given collective operation inside an MPI program?
As far as I understand the documentation, I can only use the I_MPI_ADJUST environment variables.
Is that correct or is there an API (perhaps undocumented)?
Thank you
