Intel® oneAPI HPC Toolkit
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
1988 Discussions
Can't terminate openmp-offload programs with Ctrl-C.
MehdiChinoune
Can't terminate programs built for OpenMP-Offloading using Ctrl-C.
Hardware:
  CPU: Intel Xeon E3-1505m v6
  GPU: Intel HD Graphics P630
Software:
  OS: Windows 10 Pro 20H2 and Ubuntu 20.04 and Ubuntu 20.10
  Toolkit:
      - Windows: Intel OneAPI HPC Toolkit / Intel Fortran Compiler 2021.1 (ifx)
      - Ubuntu: intel-oneapi-compiler-fortran from intel apt repositories.
  GPU driver version:
      - Windows: 27.20.100.9030
      - Ubuntu: preinstalled + intel-opencl-icd
Labels (2)
AbhishekD_Intel
In which environment you are getting this issue? Are you are using OpenMP offload on Windows or Ubuntu?
Also, try to set LIBOMPTARGET_PLUGIN=LEVEL0 before running executable if you are on Windows, or try to export LIBOMPTARGET_PLUGIN=LEVEL0 before running executable if you are using Ubuntu.
If you still face any issues while using OpenMP offload do let us know and send us a small reproducer so that we will get more insight into your issues.
Warm Regards,
Abhishek
MehdiChinoune
As you have mentioned in another post openmp-offloading with LEVEL0 plugin doesn't run on Windows.
The same applies for Ubuntu with packages installed from default repositories.
This is a reproducer.
program main
  implicit none
  integer, parameter :: sp = selected_real_kind(6,37)
  integer :: i, j, k
  integer :: n
  character(len=5) :: var
  real(sp), allocatable :: a(:,:), b(:,:), c(:,:), cc(:,:)
  integer :: t1, t2, t3
  real(sp) :: tic
  call get_command_argument( 1, var )
  read( var, '(i5.3)') n
  print*, n
  allocate( a(n,n), b(n,n), c(n,n), cc(n,n) )
  call random_number(a)
  call random_number(b)
  c = 0._sp
  call system_clock(t1, tic)
  cc = 0._sp
  do j = 1, n
    do k = 1, n
      do i = 1, n
	cc(i,j) = a(i,k)*b(k,j) + cc(i,j)
      end do
    end do
  end do
  call system_clock( t2 )
  print*, "T1 = ", (t2-t1)/tic
  !$omp target teams distribute parallel do collapse(3) map( to:a,b) map( tofrom:c )
  do j = 1, n
    do k = 1, n
      do i = 1, n
	    c(i,j) = a(i,k)*b(k,j) + c(i,j)
      end do
    end do
  end do
  call system_clock(t3)
  print*, "T2 = ", (t3-t2)/tic
  print*, "Max(|C2-C1|) = ", maxval( abs(cc-c) )
end program main
 After building using "ifx /Qiopenmp /Qopenmp-targets=spir64 matmul.f90", and running ".\matmul.exe 1024". it doesn't terminate while it's running when I press "Ctrl-C".
MehdiChinoune
After setting LIBOMPTARGET_PLUGIN=OPENCL on Windows and Installing intel-opencl-icd on Ubuntu, I don't see that behavior.
AbhishekD_Intel
This OpenMP offload issue with level-zero is with both Windows as well as Linux, whereas if you tried the above workaround your code will work run on Intel GPU.
Please let us know if you have any other issues and also give us confirmation if this issue is resolved.
Warm Regards,
Abhishek
AbhishekD_Intel
As your issue is resolved we will no longer monitor this thread. Please post a new thread if you have any issues.
Warm Regards,
Abhishek
