Intel® oneAPI HPC Toolkit
1987 Discussions
Correct way to compiling DPC++/MPI code
Viet-Duc
Dear Support Team,
I am compiling a hybrid DPC++/MPI taken from oneAPI sample codes.
I also attached the file for reference.
Could you let me know what is the correct way to compile and run the code ?
1. According to the sample code itself:
mpiicpc -cxx=dpcpp pi_mpi_dpcpp.cpp -o pi_mpi.x
 Compilation was successful. Yet, the following error was generated when running:
$ qsub -I -l nodes=1:gen9:ppn=2
$ mpirun -np 2 ./pi_mpi.x
[0] MPI startup(): I_MPI_PM environment variable is not supported.
[0] MPI startup(): Similar variables:
         I_MPI_PIN
         I_MPI_SHM
         I_MPI_PLATFORM
         I_MPI_PMI
         I_MPI_PMI_LIBRARY
[0] MPI startup(): I_MPI_RANK_CMD environment variable is not supported.
[0] MPI startup(): I_MPI_CMD environment variable is not supported.
         I_MPI_CC
[0] MPI startup(): To check the list of supported variables, use the impi_info utility or refer to https://software.intel.com/en-us/mpi-library/documentation/get-started.
Abort was called at 39 line in file:
/opt/src/opencl/shared/source/built_ins/built_ins.cpp
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 241139 RUNNING AT s001-n141
=   EXIT CODE: 6
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
   Intel(R) MPI Library troubleshooting guide:
      https://software.intel.com/node/561764
2. According to github: (https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2B/ParallelPattern...)
The correct compilation should be:
$ mpiicpc -O3 -fsycl -std=c++17 -fsycl-unnamed-lambda pi_mpi_dpcpp.cpp
Compilation failed with the following error:
icpc: error #10408: The Intel(R) oneAPI DPC++ compiler cannot be found in the expected location.  Please check your installation or documentation for more information.
/glob/development-tools/versions/oneapi/2022.3.1/oneapi/compiler/2022.2.1/linux/bin/clang++: No such file or directory
Perhaps the path to clang++ compiler was not correctly set.  Please kindly advise.
Regards.
JaideepK_Intel
Thank you for posting in Intel communities.
We were able to reproduce your issue from our end and working on this internally. We will get back to you with an update.
Jaideep
Viet-Duc
Dear Jaideep,
Thanks for looking into this issue.
I was able to make a little bit progress by manually setting I_MPI_CXX, i.e.
$ export I_MPI_CXX=dpcpp
$ mpiicpc -fsycl -std=c++17 -lsycl pi_mpi_dpcpp.cpp -o pi_mpi.x
Compilation succeeded, and correct result was observed with CPU backend:
$ SYCL_PI_TRACE=1 SYCL_DEVICE_FILTER=opencl:cpu mpirun -np 2 ./pi_mpi.x
SYCL_PI_TRACE[all]: Selected device ->
SYCL_PI_TRACE[all]:   platform: Intel(R) OpenCL
SYCL_PI_TRACE[all]:   device: 11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz
Rank? 0 of 2 runs on: s019-n002, uses device: 11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz
Rank? 1 of 2 runs on: s019-n002, uses device: 11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz
---> pi= 3.14159
For GPU backend, an exception was caught.
YCL_PI_TRACE[basic]: Plugin found and successfully loaded: libpi_opencl.soSYCL_PI_TRACE[basic]: Plugin found and successfully loaded: libpi_opencl.so
SYCL_PI_TRACE[all]:   platform: Intel(R) OpenCL HD Graphics
SYCL_PI_TRACE[all]:   device: Intel(R) UHD Graphics [0x9a60]
Rank? 0 of 2 runs on: s019-n002, uses device: Intel(R) UHD Graphics [0x9a60]
Failure
Rank? 1 of 2 runs on: s019-n002, uses device: Intel(R) UHD Graphics [0x9a60]
Failure
---> pi= 0
Unfortunately, the exception does not provides much information but the 'Failure' message. I re-factor the code by removing try/catch clause. Please refer to the attached file. The exact error message is:
$ SYCL_PI_TRACE=1 SYCL_DEVICE_FILTER=opencl:gpu mpirun -np 2 pi_mpi.x
terminate called after throwing an instance of 'cl::sycl::compile_program_error'
  what():  The program was built for 1 devices
Build program log for 'Intel(R) UHD Graphics [0x9a60]':
 -6 (CL_OUT_OF_HOST_MEMORY)
=   PID 495706 RUNNING AT s019-n002
=   EXIT CODE: 1
=   EXIT CODE: 1
I only have access to gen9/gen11 queue from Intel DevCloud and cannot validate the code elsewhere.
JaideepK_Intel
Sorry for the delay, we are working on this internally. We will get back to you with an update.
Jaideep
