I trying to manually spawn MPI processes. This code works fine when compiled with gfortran and linked against the OpenMPI libraries but when I compile it using ifort and the Intel MPI libraries, it results in an internal crash within the MPI_COMM_SPAWN_MULTIPLE subroutine. The relevant code is
ALLOCATE(commands(num_processes - 1)) ALLOCATE(args(num_processes - 1,2)) ALLOCATE(info(num_processes - 1)) ALLOCATE(max_procs(num_processes - 1)) ALLOCATE(error_array(num_processes - 1)) commands = TRIM(context%cl_parser%command) args(:,1) = temp_string IF (num_threads .lt. 0) THEN args(:,2) = '-para=-1' ELSE IF (num_threads .lt. 10) THEN WRITE (temp_string, 1001) num_threads args(:,2) = TRIM(temp_string) ELSE WRITE (temp_string, 1002) num_threads args(:,2) = TRIM(temp_string) END IF max_procs = 1 DO i = 2, num_processes CALL MPI_INFO_CREATE(info(i - 1), error) CALL MPI_INFO_SET(info(i - 1), "wdir", process_dir(i), & & error) END DO CALL MPI_COMM_SPAWN_MULTIPLE(num_processes - 1, commands, args, & & max_procs, info, 0, & & MPI_COMM_WORLD, child_comm, & & error_array, error) CALL MPI_INTERCOMM_MERGE(child_comm, .false., & & context%intra_comm, error) DO i = 1, num_processes - 1 CALL MPI_INFO_FREE(info(i), error) END DO DEALLOCATE(info) DEALLOCATE(max_procs) DEALLOCATE(args) DEALLOCATE(commands) DEALLOCATE(error_array)
When run this results in a segmentation fault internal to MPI_COMM_SPAWN_MULTIPLE. With the following error
Program received signal SIGSEGV, Segmentation fault. 0x00002aaaaadeb304 in pmpi_comm_spawn_multiple__ () from /usr/local/intel/impi/3.2.0.011/lib64/libmpiif.so.3.2
Is there something that I'm doing wrong here to cause this?
For more complete information about compiler optimizations, see our Optimization Notice.
