Intel® oneAPI HPC Toolkit
2003 Discussions
Error building OpenMPI with intel compiler:
keyurjoshi
we have a Intel® Core™ i9-7900X CPU @ 3.30GHz × 20 workstation , running ubuntu 20.04.
I have installed intel oneAPI 2022.0.2.
I am trying to build openmpi library that works with this intel oneAPI.
In past I have built separate openmpi libraries that go with gcc compilers and intel compilers.
This time it is different. It is failing in build mart itself.
I have this set up in my .bashrc
source /opt/intel/oneapi/setvars.sh
export F77=ifort
export FC=ifort
export F90=ifort
export CC=icc
export CXX=icpc
export PATH=$PATH:/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64:/opt/intel_openmpi/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/intel_openmpi/lib:opt/intel/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin
export LD_RUN_PATH=$LD_RUN_PATH:/opt/intel_openmpi/lib
and I am running in build directory of openmpi unpacked directory.
$ ../configure -prefix=/opt/intel_openmpi CC=icc CXX=icpc F77=ifort FC=ifort
and upon
$ sudo make all install
It fails with the following error message:
Making all in config
make[1]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/config'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/config'
Making all in contrib
make[1]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/contrib'
make[1]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/contrib'
Making all in opal
make[1]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal'
Making all in include
make[2]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal/include'
make all-am
make[3]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal/include'
make[3]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal/include'
make[2]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal/include'
Making all in datatype
make[2]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal/datatype'
CC libdatatype_reliable_la-opal_datatype_pack.lo
../../libtool: line 1766: icc: command not found
make[2]: *** [Makefile:1916: libdatatype_reliable_la-opal_datatype_pack.lo] Error 1
make[2]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal/datatype'
make[1]: *** [Makefile:2383: all-recursive] Error 1
make[1]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/opal'
make: *** [Makefile:1901: all-recursive] Error 1
The specific reason : libtool can't find icc.
icc is in the path for sure. but still I keep getting this error.
Any help will be appreciated.
I have a legacy code that is configured to be built with intel+openMPI combination.
Keyur
VarshaS_Intel
Could you please let us know if you are able to get the version of icc after sourcing Intel oneAPI environment(source /opt/intel/oneapi/setvars.sh)?
Please find the below command to get the version.
icc --version
Could you try giving the complete path for all the compilers at the time of configuring?
./configure --prefix=$<path> CC=/opt/intel/oneapi/compiler/<version>/linux/bin/intel64/icc CXX=/opt/intel/oneapi/compiler/<version>/linux/bin/intel64/icpc F77=/opt/intel/oneapi/compiler/<version>/linux/bin/intel64/ifort FC=/opt/intel/oneapi/compiler/<version>/linux/bin/intel64/ifort
After configuring, please use the "make all" command.
make all
After using the command "make all". Now, use the "make all install" command.
make all install
Could you please try and let us know if you are still facing any issues?
Thanks & Regards,
Varsha
keyurjoshi
Hello Varsha,
                       thanks for responding. I went a bit ahead, I think but still facing other kind of error.
icc version prints 2021.05
$ icc --version
icc (ICC) 2021.5.0 20211109
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
but at /opt/intel/oneapi/compiler there's version dir 2022.0.2 and a softlink directory latest
$ ls /opt/intel/oneapi/compiler
2022.0.2 latest
 there's no 2021.5.0 dir under /opt/intel/oneapi/compiler.
$ ../configure -prefix=/opt/intel_openmpi CC=/opt/intel/oneapi/compiler/2021.5.0/linux/bin/intel64/icc CXX=/opt/intel/oneapi/compiler/2015.5.0/linux/bin/intel64/icpc F77=/opt/intel/oneapi/compiler/2021.5.0/linux/bin/intel64/ifort FC=/opt/intel/oneapi/compiler/2021.5.0/linux/bin/intel64/ifort 2>&1 |tee config.out
checking for perl... perl
== Configuring Open MPI
*** Startup tests
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for gcc... /opt/intel/oneapi/compiler/2021.5.0/linux/bin/intel64/icc
checking whether the C compiler works... no
configure: error: in `/home/smec17045/setup/openmpi-4.1.2/build_intel':
configure: error: C compiler cannot create executables
See `config.log' for more details
configured with the following worked.
../configure -prefix=/opt/intel_openmpi CC=/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/icc CXX=/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/icpc F77=/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/ifort FC=/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/ifort 2>&1 |tee config.out
and upon make all got the error trying to load "libimf.so". I am printing only a few tail end lines of the output.
$ make all
 LN_S ptype_ub_f.c
CC ptype_ub_f.lo
GENERATE psizeof_f.f90
FC psizeof_f.lo
FCLD libmpi_mpifh_psizeof.la
ar: `u' modifier ignored since `D' is the default (see `U')
CCLD libmpi_mpifh_pmpi.la
make[3]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi/mpi/fortran/mpif-h/profile'
make[3]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi/mpi/fortran/mpif-h'
GENERATE sizeof_f.f90
FC sizeof_f.lo
FCLD libmpi_mpifh_sizeof.la
CCLD libmpi_mpifh.la
make[3]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi/mpi/fortran/mpif-h'
make[2]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi/mpi/fortran/mpif-h'
Making all in mpi/fortran/use-mpi-ignore-tkr
make[2]: Entering directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi/mpi/fortran/use-mpi-ignore-tkr'
GENERATE mpi-ignore-tkr-sizeof.h
GENERATE mpi-ignore-tkr-sizeof.f90
PPFC mpi-ignore-tkr.lo
FC mpi-ignore-tkr-sizeof.lo
FCLD libmpi_usempi_ignore_tkr.la
ifort: command line warning #10434: option '-nofor_main' use with underscore is deprecated; use '-nofor-main' instead
ld: /opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/../../bin/intel64/../../lib/icx-lto.so: error loading plugin: libimf.so: cannot open shared object file: No such file or directory
make[2]: *** [Makefile:1903: libmpi_usempi_ignore_tkr.la] Error 1
make[2]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi/mpi/fortran/use-mpi-ignore-tkr'
make[1]: *** [Makefile:3555: all-recursive] Error 1
make[1]: Leaving directory '/home/smec17045/setup/openmpi-4.1.2/build_intel/ompi'
  Thanks for your help! Hope you can help me with this one too.
-- Keyur
VarshaS_Intel
Could you please try exporting the libraries only if you did not find them after initializing the Intel oneAPI Environment?
And also, could you please try the command "make" after the configure step and the "make all install"?
make
make all install
Thanks & Regards,
Varsha
keyurjoshi
Thanks again!! @VarshaS_Intel
You mentioned
"Could you please try exporting the libraries only if you did not find them after initializing the Intel oneAPI Environment?"
Can you please elaborate what you mean by "exporting the libraries"? I am not sure what you mean by exporting the library?
The library is located in $LD_LIBRARY_PATH correctly. however somehow it cannot be linked.
Also, on another note: I found ifort application fails to build with intel oneAPI on multiple (3 separate servers) different version. The applications that don't even need mpi also fails.
2022.0.2 (2)
2021.1.1
all with pretty much similar error message.
ifort -check all -check noarg_temp_created -traceback -g -qopenmp -c solver_omp.f90 -o solver.o
ifort -check all -check noarg_temp_created -traceback -g -c NonLinearFEM.f90
ifort -check all -check noarg_temp_created -traceback -g -qopenmp NonLinearFEM.o assembly.o connectivity.o bc.o solver.o plotter.o postprocess.o preprocess.o metis_interface.o metis_h.o -o nlfem.x /home/hpcsmec17045/TecioLib/libtecio.a -lstdc++ -limf -lmetis
ifort: warning #10182: disabling optimization; runtime debug checks enabled
ld: /opt/intel/oneapi/compiler/2021.1.1/linux/bin/intel64/../../bin/intel64/../../lib/icx-lto.so: error loading plugin: libimf.so: cannot open shared object file: No such file or directory
make: *** [makefile:45: nlfem.x] Error 1
All these points to some issue with linking "libimf.so" in my humble opinion.
Thanks and regards,
Keyur
VarshaS_Intel
After initializing the Intel oneAPI environment, all the libraries will be set in LD_LIBRARY_PATH. You can export the libraries only if you didn't find them after initializing the oneAPI.
I am able to build the OpenMPI with the Intel compilers without getting any errors. Please find the below screenshot of it during "make":
And also, we want to let you know that Intel oneAPI has its own MPI where you can able to use it just by initializing the oneAPI environment. You just need to install the Intel HPC Toolkit and do initialize the oneAPI environment to use the Intel MPI Library.
To download Intel HPC Toolkit please find the below link:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/hpc-toolkit-download.html
To set up the oneAPI environment, use the below command:
source /opt/intel/oneapi/mpi/2021.5.0/env/vars.sh
To compile & run a sample MPI program:
https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/compiling-and-linking/compiling-an-mpi-program.html
Also, could you please let us know the specific reason for using the OpenMPI rather than Intel MPI so that your feedback helps us to understand better about your issue?
Thanks & Regards,
Varsha
keyurjoshi
Thank you for the response. It seems perhaps the installation itself has some issue. I am unable to build even basic MPI application with intel compiler, let alone building openmpi library.
This is listing of hello_mpi.f90
PROGRAM hello_world_mpi
include 'mpif.h'
integer process_Rank, size_Of_Cluster, ierror, tag
call MPI_INIT(ierror)
call MPI_COMM_SIZE(MPI_COMM_WORLD, size_Of_Cluster, ierror)
call MPI_COMM_RANK(MPI_COMM_WORLD, process_Rank, ierror)
print *, 'Hello World from rank: ', process_Rank, 'of ', size_Of_Cluster,' total ranks'
call MPI_FINALIZE(ierror)
END PROGRAM hello_world_mpi
I am building it with mpiifort with debug flag on.
$ mpiifort -g -O0 -o hello_mpi hello_mpi.f90
And tried debugging what is causing the error. It seems MPI_INIT  call itself fails.
$ mpirun -n 1 gdb ./hello_mpi
GNU gdb (Ubuntu 9.2-0ubuntu1~20.04.1) 9.2
Copyright (C) 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./hello_mpi...
(gdb) b hello_world_mpi
Breakpoint 1 at 0x4038dc: file hello_mpi.f90, line 4.
(gdb) list
1 PROGRAM hello_world_mpi
2 include 'mpif.h'
3 integer process_Rank, size_Of_Cluster, ierror, tag
4 call MPI_INIT(ierror)
5 call MPI_COMM_SIZE(MPI_COMM_WORLD, size_Of_Cluster, ierror)
6 call MPI_COMM_RANK(MPI_COMM_WORLD, process_Rank, ierror)
7 print *, 'Hello World from rank: ', process_Rank, 'of ', size_Of_Cluster,' total ranks'
8 call MPI_FINALIZE(ierror)
9 END PROGRAM hello_world_mpi
(gdb) r
Starting program: /home/smec17045/hello_mpi
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Breakpoint 1, hello_world_mpi () at hello_mpi.f90:4
(gdb) n
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff5710131 in ofi_cq_sreadfrom ()
from /opt/intel/oneapi/mpi/2021.5.1//libfabric/lib/prov/libsockets-fi.so
(gdb) q
A debugging session is active.
Inferior 1 [process 40610] will be killed.
Quit anyway? (y or n) [answered Y; input not from terminal]
Any further guidance on how to resolve this would be appreciated. Should I try reinstalling the intel-Oneapi-Base-kit?
-- Keyur
VarshaS_Intel
Could you please try compiling and running the sample Fortran MPI Helloworld by using the below commands?
For Compiling, use the below command:
mpiifort -o hello hello.f90
For Running the MPI program, use the below command:
mpirun -n 2 ./hello
Could you please check if you are able to get the results for "hostname" by using the below command? Please find the below screenshot for more information.
mpirun -n 2 hostname
If you are facing errors while running the above cases, then could you please try reinstalling and running the above cases again?
Please do let us know if you are facing the issues even after reinstalling the toolkits.
Thanks & Regards,
Varsha
keyurjoshi
Thank you for the reply!
On the workstation where original problem exists:
I compiled and ran the code as per your suggestion. here is what I am getting.
$ mpiifort -o hello hello.f90
$ mpirun -n 2 hello
[proxy:0:0@tt433gpu1] HYD_spawn (../../../../../src/pm/i_hydra/libhydra/spawn/intel/hydra_spawn.c:146): execvp error on file hello (No such file or directory)
 Further, hostname is as follows.
$ mpirun -n 2 hostname
tt433gpu1
tt433gpu1
Another check on a compute cluster:
- On login node
On another compute cluster, with multiple nodes also I tried to check.
- On the login node doing the following resulted in similar result.
I checked the same with another version of toolkit on a different server 2021.1.1 and it also fails this case in similar manner.
hpcvisualization
hpcvisualization
$ mpiifort -o hello_mpi hello_mpi.f90
$ mpirun -n 2 hello_mpi
[proxy:0:0@hpcvisualization] HYD_spawn (../../../../../src/pm/i_hydra/libhydra/spawn/intel/hydra_spawn.c:145): execvp error on file hello_mpi (No such file or directory)
 Line number of error reporting differs by 1.
- On interactive queue:
- On development queue, requested with 2 nodes however, it seems to work, not without any issue though, It reports some issues with respect to libnuma.so but seems to give desired output also.
$ qsub -I -lwalltime=2:00:00 -lnodes=2
qsub: waiting for job 2339.hpcmaster to start
qsub: job 2339.hpcmaster ready
$ cd fortran/mpi_basic/
$ module purge
$ module load compiler/2021.1.1 mpi/2021.1.1
hpcnode-1
hpcnode-2
$ mpirun -n 2 ./hello_mpi
[LOG_CAT_SBGP] libnuma.so: cannot open shared object file: No such file or directory
[LOG_CAT_SBGP] Failed to dlopen libnuma.so. Fallback to GROUP_BY_SOCKET manual.
Hello World from rank: 1 of 2 total ranks
Hello World from rank: 0 of 2 total ranks
- On normal queue:
Again the  issue resurfaces if submitted through normal queue. Please find the tarball attached with source, output file, error file and submit script.
 I hope this helps in trouble shooting what's the issue with my workstation installation.
Thank you for your time and inputs!
-- Keyur
VarshaS_Intel
Thanks for providing the detailed information.
From the steps given by you((On the workstation where original problem exists, On login node), we have observed that while running the MPI code you were using the command "mpirun -n 2 hello" instead of "mpirun -n 2 ./hello".
We can face a similar issue if the binary file path is wrong. Please refer to the below image in which we were able to reproduce the same issue.
Please find the below link for more information:
https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/troubleshooting/error-message-no-such-file-or-directory.html
We suggest you try running the below command and let us know if it works:
mpirun -n 2 -ppn 1 ./hello
On the interactive queues, could you please try the below command for checking the correctness of the MPI code?
mpirun -check_mpi -n 2 -ppn 1 ./hello
If there is no issue with the MPI code, then it will appear as present in the below screenshot :
Could you please provide us with the results using the below command for the normal queue:
mpirun -check_mpi -n 2 -ppn 1 I_MPI_DEBUG = 30 FI_LOG_LEVEL=debug ./hello
Thanks & Regards,
Varsha
keyurjoshi
Thanks you for your reply!
On Workstation where original problem exists:
Ok, you were right, on this account. It seems I might have missed giving correct path as "./hello".
However the problem exists even with correct path. It segfaults in the very first line. as clear from gdb session.
$ mpirun -n 2 -ppn 2 ./hello_mpi
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 5910 RUNNING AT tt433gpu1
= KILLED BY SIGNAL: 9 (Killed)
= RANK 1 PID 5911 RUNNING AT tt433gpu1
= KILLED BY SIGNAL: 11 (Segmentation fault)
(gdb) list
2 include 'mpif.h'
(gdb) b main
Breakpoint 1 at 0x403870
(gdb) r
Breakpoint 1, 0x0000000000403870 in main ()
(gdb) n
Single stepping until exit from function main,
which has no line number information.
0x0000155552c67131 in ofi_cq_sreadfrom ()
(gdb) q
Inferior 1 [process 5950] will be killed.
On Compute Cluster:  Interactive queue:
$ mpirun -check_mpi -n 2 -ppn 1 ./hello_mpi
[0] INFO: CHECK LOCAL:EXIT:SIGNAL ON
[0] INFO: CHECK LOCAL:EXIT:BEFORE_MPI_FINALIZE ON
[0] INFO: CHECK LOCAL:MPI:CALL_FAILED ON
[0] INFO: CHECK LOCAL:MEMORY:OVERLAP ON
[0] INFO: CHECK LOCAL:MEMORY:ILLEGAL_MODIFICATION ON
[0] INFO: CHECK LOCAL:MEMORY:INACCESSIBLE ON
[0] INFO: CHECK LOCAL:MEMORY:ILLEGAL_ACCESS OFF
[0] INFO: CHECK LOCAL:MEMORY:INITIALIZATION OFF
[0] INFO: CHECK LOCAL:REQUEST:ILLEGAL_CALL ON
[0] INFO: CHECK LOCAL:REQUEST:NOT_FREED ON
[0] INFO: CHECK LOCAL:REQUEST:PREMATURE_FREE ON
[0] INFO: CHECK LOCAL:DATATYPE:NOT_FREED ON
[0] INFO: CHECK LOCAL:BUFFER:INSUFFICIENT_BUFFER ON
[0] INFO: CHECK GLOBAL:DEADLOCK:HARD ON
[0] INFO: CHECK GLOBAL:DEADLOCK:POTENTIAL ON
[0] INFO: CHECK GLOBAL:DEADLOCK:NO_PROGRESS ON
[0] INFO: CHECK GLOBAL:MSG:DATATYPE:MISMATCH ON
[0] INFO: CHECK GLOBAL:MSG:DATA_TRANSMISSION_CORRUPTED ON
[0] INFO: CHECK GLOBAL:MSG:PENDING ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:DATATYPE:MISMATCH ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:DATA_TRANSMISSION_CORRUPTED ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:OPERATION_MISMATCH ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:SIZE_MISMATCH ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:REDUCTION_OPERATION_MISMATCH ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:ROOT_MISMATCH ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:INVALID_PARAMETER ON
[0] INFO: CHECK GLOBAL:COLLECTIVE:COMM_FREE_MISMATCH ON
[0] INFO: maximum number of errors before aborting: CHECK-MAX-ERRORS 1
[0] INFO: maximum number of reports before aborting: CHECK-MAX-REPORTS 0 (= unlimited)
[0] INFO: maximum number of times each error is reported: CHECK-SUPPRESSION-LIMIT 10
[0] INFO: timeout for deadlock detection: DEADLOCK-TIMEOUT 60s
[0] INFO: timeout for deadlock warning: DEADLOCK-WARNING 300s
[0] INFO: maximum number of reported pending messages: CHECK-MAX-PENDING 20
[0] INFO: Error checking completed without finding any problems
On Compute Cluster:  normal queue:
On normal queue the run with the following command
$ mpirun -check_mpi -n 2 -ppn 1 I_MPI_DEBUG = 30 FI_LOG_LEVEL=debug ./hello_mpi >out.txt
produces the following in error file.
Loading compiler version 2021.1.1
Loading tbb version 2021.1.1
Loading debugger version 10.0.0
Loading compiler-rt version 2021.1.1
Loading dpl version 2021.1.1
Loading oclfpga version 2021.1.1
Loading init_opencl version 2021.1.1
Warning: Intel PAC device is not found.
Please install the Intel PAC card to execute your program on an FPGA device.
Loading compiler/2021.1.1
Loading requirement: tbb/latest debugger/latest compiler-rt/latest dpl/latest
/opt/intel/oneapi/compiler/2021.1.1/linux/lib/oclfpga/modulefiles/init_opencl /opt/intel/oneapi/compiler/2021.1.1/linux/lib/oclfpga/modulefiles/oclfpga
Loading mpi version 2021.1.1
Currently Loaded Modulefiles:
1) tbb/latest
2) debugger/latest
3) compiler-rt/latest
4) dpl/latest
5) /opt/intel/oneapi/compiler/2021.1.1/linux/lib/oclfpga/modulefiles/init_opencl
6) /opt/intel/oneapi/compiler/2021.1.1/linux/lib/oclfpga/modulefiles/oclfpga
7) compiler/2021.1.1
mpi/2021.1.1
9) lib/cmake/cmake-3.19.4
cp: cannot create regular file \u2018/hello_mpi\u2019: Permission denied
[proxy:0:1@hpcnode-2] HYD_spawn (../../../../../src/pm/i_hydra/libhydra/spawn/intel/hydra_spawn.c:145): execvp error on file I_MPI_DEBUG (No such file or directory)
[mpiexec@hpcnode-1] wait_proxies_to_terminate (../../../../../src/pm/i_hydra/mpiexec/intel/i_mpiexec.c:531): downstream from host hpcnode-1 was killed by signal 9 (Killed)
Thanks and regards,
Keyur
gabrielhgobi
Hello, @VarshaS_Intel !
I'm having the exact same problem as @keyurjoshi
Running gdb debugger, I get the segfault at ofi_cq_sreadfrom().
When running all the commands of your reply above I get the same output:
= RANK 0 PID 6583 RUNNING AT dirac
= RANK 1 PID 6584 RUNNING AT dirac
I already tried to reinstall the HPC Toolkit. The same error repeats for test files in the mpi installation directory.
Thank you for helping!
VarshaS_Intel
Sorry, there is a typo in my previous response. Please use the below command for getting the complete debug log:
I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun -n 2 -ppn 1 ./hello
Please provide us with the debug log for the individual cases(On Compute Cluster: normal queue, On Workstation where original problem exists, etc.)
Could you try the below command for the cases where you are getting "BAD TERMINATION ERROR"? Also, please share the complete debug log with us.
Thanks & Regards,
Varsha
keyurjoshi
Hello Varsha,
                             thanks for the suggestion.  Here's what I got.
On HPC Cluster, normal queue:
As per your suggestion, ran the following through normal queue
I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun -n 2 -ppn 1 ./hello_mpi >out.txt
The error channel output is as follows:
/opt/intel/oneapi/compiler/2021.1.1/linux/lib/oclfpga/modulefiles/init_opencl /opt/intel/oneapi/compiler/2021.1.1/linux/lib/oclfpga/modul\
efiles/oclfpga
1) tbb/latest
2) debugger/latest
4) dpl/latest
mpi/2021.1.1
libfabric:28642:core:core:ofi_hmem_init():202<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:28642:core:core:ofi_hmem_init():202<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:28642:core:core:ofi_hmem_init():202<info> Hmem iface FI_HMEM_ZE not supported
libfabric:28642:core:mr:ofi_default_cache_size():69<info> default cache size=4223952597
libfabric:14757:core:core:ofi_hmem_init():202<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:14757:core:core:ofi_hmem_init():202<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:14757:core:core:ofi_hmem_init():202<info> Hmem iface FI_HMEM_ZE not supported
libfabric:14757:core:mr:ofi_default_cache_size():69<info> default cache size=4223952597
libfabric:28642:verbs:fabric:verbs_devs_print():871<info> list of verbs devices found for FI_EP_MSG:
libfabric:28642:verbs:fabric:verbs_devs_print():875<info> #1 mlx5_0 - IPoIB addresses:
libfabric:28642:verbs:fabric:verbs_devs_print():885<info> 192.168.2.2
libfabric:28642:verbs:fabric:verbs_devs_print():885<info> fe80::63f:7203:ae:a922
libfabric:14757:verbs:fabric:verbs_devs_print():871<info> list of verbs devices found for FI_EP_MSG:
libfabric:14757:verbs:fabric:verbs_devs_print():875<info> #1 mlx5_0 - IPoIB addresses:
libfabric:14757:verbs:fabric:verbs_devs_print():885<info> 192.168.2.3
libfabric:14757:verbs:fabric:verbs_devs_print():885<info> fe80::63f:7203:ae:a93e
libfabric:28642:verbs:fabric:vrb_get_device_attrs():617<info> device mlx5_0: first found active port is 1
libfabric:14757:verbs:fabric:vrb_get_device_attrs():617<info> device mlx5_0: first found active port is 1
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: verbs (111.0)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: verbs (111.0)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: tcp (111.0)
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: tcp (111.0)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: sockets (111.0)
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: sockets (111.0)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: shm (111.0)
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: shm (111.0)
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: ofi_rxm (111.0)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: ofi_rxm (111.0)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: mlx (1.4)
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: mlx (1.4)
libfabric:14757:core:core:ofi_register_provider():427<info> registering provider: ofi_hook_noop (111.0)
libfabric:14757:core:core:fi_getinfo_():1117<info> Found provider with the highest priority mlx, must_use_util_prov = 0
ibfabric:14757:mlx:core:mlx_getinfo():172<info> used inject size = 1024
libfabric:14757:mlx:core:mlx_getinfo():219<info> Loaded MLX version 1.10.0
libfabric:14757:mlx:core:mlx_getinfo():266<warn> MLX: spawn support 0
libfabric:14757:core:core:fi_getinfo_():1144<info> Since mlx can be used, verbs has been skipped. To use verbs, please, set FI_PROVIDER=verbs
libfabric:14757:core:core:fi_getinfo_():1144<info> Since mlx can be used, tcp has been skipped. To use tcp, please, set FI_PROVIDER=tcp
libfabric:14757:core:core:fi_getinfo_():1144<info> Since mlx can be used, sockets has been skipped. To use sockets, please, set FI_PROVIDER=s\
ockets
libfabric:14757:core:core:fi_getinfo_():1144<info> Since mlx can be used, shm has been skipped. To use shm, please, set FI_PROVIDER=shm
libfabric:14757:mlx:core:mlx_getinfo():172<info> used inject size = 1024
ockets
libfabric:14757:mlx:core:mlx_fabric_open():172<info>
libfabric:14757:core:core:fi_fabric_():1397<info> Opened fabric: mlx
libfabric:14757:mlx:core:ofi_check_rx_attr():785<info> Tx only caps ignored in Rx caps
libfabric:14757:mlx:core:ofi_check_tx_attr():883<info> Rx only caps ignored in Tx caps
libfabric:28642:core:core:ofi_register_provider():427<info> registering provider: ofi_hook_noop (111.0)
libfabric:28642:core:core:fi_getinfo_():1117<info> Found provider with the highest priority mlx, must_use_util_prov = 0
libfabric:28642:mlx:core:mlx_getinfo():172<info> used inject size = 1024
libfabric:28642:mlx:core:mlx_getinfo():219<info> Loaded MLX version 1.10.0
libfabric:28642:mlx:core:mlx_getinfo():266<warn> MLX: spawn support 0
libfabric:28642:core:core:fi_getinfo_():1144<info> Since mlx can be used, verbs has been skipped. To use verbs, please, set FI_PROVIDER=verbs
libfabric:28642:core:core:fi_getinfo_():1144<info> Since mlx can be used, tcp has been skipped. To use tcp, please, set FI_PROVIDER=tcp
libfabric:28642:core:core:fi_getinfo_():1144<info> Since mlx can be used, sockets has been skipped. To use sockets, please, set FI_PROVIDER=s\
ockets
libfabric:28642:core:core:fi_getinfo_():1144<info> Since mlx can be used, shm has been skipped. To use shm, please, set FI_PROVIDER=shm
ockets
libfabric:28642:mlx:core:mlx_fabric_open():172<info>
libfabric:28642:core:core:fi_fabric_():1397<info> Opened fabric: mlx
libfabric:28642:mlx:core:ofi_check_rx_attr():785<info> Tx only caps ignored in Rx caps
libfabric:28642:mlx:core:ofi_check_tx_attr():883<info> Rx only caps ignored in Tx caps
libfabric:14757:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:28642:mlx:core:mlx_cm_getname_mlx_format():73<info> Loaded UCP address: [307]...
libfabric:28642:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x20eff80
libfabric:14757:mlx:core:mlx_av_insert():179<warn> Try to insert address #0, offset=0 (size=2) fi_addr=0x1b0cfa0
libfabric:14757:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:14757:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x1b0cfa0
libfabric:28642:mlx:core:mlx_av_insert():189<warn> address inserted
libfabric:28642:mlx:core:mlx_av_insert():179<warn> Try to insert address #1, offset=1024 (size=2) fi_addr=0x20eff80
and it writes these to console that I have redirected to a file.
[0] MPI startup(): Intel(R) MPI Library, Version 2021.1 Build 20201112 (id: b9c9d2fc5)
[0] MPI startup(): Copyright (C) 2003-2020 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): Size of shared memory segment (857 MB per rank) * (2 local ranks) = 1715 MB total
[0] MPI startup(): libfabric version: 1.11.0-impi
[0] MPI startup(): libfabric provider: mlx
[0] MPI startup(): detected mlx provider, set device name to "mlx"
[0] MPI startup(): max_ch4_vcis: 1, max_reg_eps 1, enable_sep 0, enable_shared_ctxs 0, do_av_insert 1
[0] MPI startup(): addrnamelen: 1024
[0] MPI startup(): Load tuning file: "/opt/intel/oneapi/mpi/2021.1.1/etc/tuning_skx_shm-ofi.dat"
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 153103 hpcvisualization {0,1,2,3,4,5,6,7,8,9,20,21,22,23,24,25,26,27,28,29}
[0] MPI startup(): 1 153104 hpcvisualization {10,11,12,13,14,15,16,17,18,19,30,31,32,33,34,35,36,37,38,39}
[0] MPI startup(): I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.1.1
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_DEBUG=30
The following run with
produces the following on error channel
efiles/oclfpga
1) tbb/latest
2) debugger/latest
4) dpl/latest
mpi/2021.1.1
[0] INFO: Error checking completed without finding any problems.
And it produces the following relevant output.
I don't know what changed between earlier runs and today's but even regular run with
mpirun -n 2 -ppn 1 ./hello_mpi > out.txt
 also produces correct output.
but prints the following on error channel. Let me know if this may cause issue in some other tun.
I will report results on "the workstation where original problem exists" with these same step a later taoday.
Thanks and Regards,
Keyur
keyurjoshi
Hello Varsha,
                  sorry for the delay.
On the Workstation where the original problem exist:
Upon running the following,
$ mpiifort -g O0 -o hello_mpi hello_mpi.f90
I got the following message.
= RANK 0 PID 49970 RUNNING AT tt433gpu1
= RANK 1 PID 49971 RUNNING AT tt433gpu1
And the following command,
$ I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun -n 2 -ppn 1 ./hello_mpi
produces the following:
[0] MPI startup(): Intel(R) MPI Library, Version 2021.5 Build 20211102 (id: 9279b7d62)
[0] MPI startup(): Copyright (C) 2003-2021 Intel Corporation. All rights reserved.
[0] MPI startup(): shm segment size (1307 MB per rank) * (2 local ranks) = 2615 MB total
libfabric:50086:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:50086:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
[0] MPI startup(): libfabric version: 1.13.2rc1-impi
libfabric:50085:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:50085:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:50086:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: Input/output error
libfabric:50086:core:mr:ofi_default_cache_size():78<info> default cache size=3368535552
libfabric:50086:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:50085:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: Input/output error
libfabric:50085:core:mr:ofi_default_cache_size():78<info> default cache size=3368535552
libfabric:50085:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:50086:verbs:fabric:vrb_init_info():1336<info> no RDMA devices found
libfabric:50086:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:50086:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:50086:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:50085:verbs:fabric:vrb_init_info():1336<info> no RDMA devices found
libfabric:50085:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:50085:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:50085:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
= RANK 0 PID 50085 RUNNING AT tt433gpu1
= RANK 1 PID 50086 RUNNING AT tt433gpu1
I hope it helps figuring out the issue.
Keyur
VarshaS_Intel
Hi @gabrielhgobi ,
Could you please let us know if you are able to get the hostname without any errors? Please find the below command:
mpirun -n 2 -ppn 1 hostname
Could you please let us know which code you are trying to run and facing the issue?
Could you please provide us with the complete debug log using the below command?
Also, could you please provide the result of the below command?
Thanks & Regards,
Varsha
VarshaS_Intel
Hi Keyur,
Glad to know that one of your issues is resolved.
We can see from the debug log(generated using -check_mpi flag) that there is no issue with the MPI code and thus the expected output got generated. The error log is related to your workstation.
On the cluster where you are facing the error "BAD TERMINATION", could you please try the below command and let us know if you are still facing any issues?
I_MPI_FABRICS=shm I_MPI_DEBUG=30 FI_LOG_LEVEL=debug mpirun -n 2 -ppn 1 ./hello_mpi
For more information, please find the below link:
https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/troubleshooting/error-message-bad-termination.html
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
gabrielhgobi
Hi, Varsha.
Sorry for the delay.
Running the following:
 I got the message
dirac
dirac
The code that I am trying to run is exactly the same hello_mpi or hello program from the others replies in the topic.
Using the command:
[0] MPI startup(): shm segment size (1068 MB per rank) * (2 local ranks) = 2136 MB total
libfabric:4589:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:4589:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:4588:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_CUDA not supported
libfabric:4588:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ROCR not supported
libfabric:4589:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: Input/output error
libfabric:4589:core:mr:ofi_default_cache_size():78<info> default cache size=2807081130
libfabric:4588:core:core:ofi_hmem_init():214<warn> Failed to initialize hmem iface FI_HMEM_ZE: Input/output error
libfabric:4588:core:mr:ofi_default_cache_size():78<info> default cache size=2807081130
libfabric:4588:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:4589:core:core:ofi_hmem_init():209<info> Hmem iface FI_HMEM_ZE not supported
libfabric:4588:verbs:fabric:vrb_init_info():1336<info> no RDMA devices found
libfabric:4588:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:4588:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:4588:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
libfabric:4589:verbs:fabric:vrb_init_info():1336<info> no RDMA devices found
libfabric:4589:core:core:ofi_register_provider():474<info> registering provider: tcp (113.20)
libfabric:4589:core:core:ofi_register_provider():474<info> registering provider: sockets (113.20)
libfabric:4589:core:core:ofi_register_provider():474<info> registering provider: shm (113.20)
=   RANK 0 PID 4588 RUNNING AT dirac
=   RANK 1 PID 4589 RUNNING AT dirac
 And running the following:
I just got the terminations:
=   RANK 0 PID 4610 RUNNING AT dirac
=   RANK 1 PID 4611 RUNNING AT dirac
Trying the command:
I got the output:
[0] MPI startup(): File "" not found
[0] MPI startup(): Load tuning file: "/opt/intel/oneapi/mpi/2021.5.1/etc/tuning_skx_shm.dat"
[0] MPI startup(): 0       4626     dirac      {0,1,2,6,7,8}
[0] MPI startup(): 1       4627     dirac      {3,4,5,9,10,11}
[0] MPI startup(): I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.5.1
[0] MPI startup(): I_MPI_FABRICS=shm
[0] MPI startup(): threading: mode: direct
[0] MPI startup(): threading: vcis: 1
[0] MPI startup(): threading: app_threads: 1
[0] MPI startup(): threading: runtime: generic
[0] MPI startup(): threading: is_threaded: 0
[0] MPI startup(): threading: async_progress: 0
[0] MPI startup(): threading: num_pools: 64
[0] MPI startup(): threading: lock_level: global
[0] MPI startup(): threading: enable_sep: 0
[0] MPI startup(): threading: direct_recv: 0
[0] MPI startup(): threading: zero_op_flags: 0
[0] MPI startup(): threading: num_am_buffers: 0
[0] MPI startup(): threading: library is built with per-vci thread granularity
 I hope it helps. Thank you for the support!
Gobi
VarshaS_Intel
Hi @gabrielhgobi,
Glad to know that your issue is resolved. Thanks for the confirmation.
Hi @keyurjoshi,
We have not heard back you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
