Intel® oneAPI HPC Toolkit
2003 Discussions
Get "https://iotdk.intel.com/samples-iss/2021.1-beta08//cpp.json": context deadline exceeded (Client
shefmarkh
I installed ones by creating:
more /etc/yum.repos.d/oneAPI.repo
[oneAPI]
name=Intel(R) oneAPI repository
enabled=1
gpgcheck=1
repo_gpgcheck=1
yum install intel-hpckit
This was done inside a linux docker container running on a linux VM in OpenStack. When I try to run oneapi-cli it fails:
oneapi-cli
Connecting to online Sample Aggregator, this may take some time based on network conditions
2020/08/13 13:45:02 failed to connect to sample aggregator, attempting to use local cache
2020/08/13 13:45:02 operating offline and local cache does not exist
Failed to fetch sample index, this *may* be your network/proxy environment.
You might try setting http_proxy in your environment, for example:
Linux: export http_proxy=http://your.proxy:8080
Windows: set http_proxy=http://your.proxy:8080
Get "https://iotdk.intel.com/samples-iss/2021.1-beta08//cpp.json": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
I seem to be able to access other external web addresses via e.g. wget, so I am unsure what the problem might be with the above command. Does someone have a suggestion of how to debug further or even fix the issue?
Mark
GouthamK_Intel
We think your proxy is blocking the web address oneapi-cli is trying to reach, to verify it could please try doing wget to below address and let us know if you are able to get it or not.
For time being, you can use the below GitHub repo where you can find all the oneAPI samples.
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2B
Thanks & Regards
Goutham
shefmarkh
Thanks for the reply. wget seems to just hang without completing. It works fine for other URL though.
In the end I got the examples via GitHub instead.
Mark
Tom_Ingleby_Intel
Curious.
  • Are you able to ping/resolve `iotdk.intel.com` ?
  • I'm guessing `curl -v https://iotdk.intel.com/samples-iss/2021.1-beta08/cpp.json` will also just timeout?
  • Is there any proxy/filtering on the internet connection from the environment?
  • Are you using IPv4 or IPv6 primary? Try use wget -4 on the URL above.
shefmarkh
Well today I apparently do not see the problem! I am running on a VM machine running on a cluster run by an organisation, so I wonder if someone has changed some setting.
Cheers,
Mark
GouthamK_Intel
Hi Mark,
Glad to know that your issue is resolved!
Feel free to raise a new thread in case of any further queries.
Could you please confirm if we can close this thread from our side?
Thanks & Regards
Goutham
shefmarkh
Yes its fine to close it.
Cheers,
Mark
GouthamK_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Goutham
