Intel® oneAPI HPC Toolkit
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
1912 Discussions
I_MPI_EAGER_THRESHOLD not supported
oleotiger
From the document , For communication across nodes the Eager / Rendezvous threshold is defined by the variable I_MPI_EAGER_THRESHOLD (in bytes, default is 256 kB).
I want to tried the performance of different threshold. But when I set the environment variable, I get errors :
[0] MPI startup(): I_MPI_EAGER_THRESHOLD environment variable is not supported.
[0] MPI startup(): Similar variables:
         I_MPI_SHM_HEAP_THRESHOLD
         I_MPI_SHM_CMA_THRESHOLD
         I_MPI_SHM_EAGER_THRESHOLD
         I_MPI_LARGE_SCALE_THRESHOLD
         I_MPI_COLL_SHM_THRESHOLD
[0] MPI startup(): I_MPI_INTRANODE_EAGER_THRESHOLD environment variable is not supported.
The document is last updated on 01/29/2018. I wonder if it is out of date.
From the latest developer reference (version 2021.2), I find no variable which can change the threshold between eager/rendezvous.
So, with oneapi 2021.2, is there any ways that I can control when to use eager protocol and when to use rendezvous protocol?
oleotiger
What's more, according to process-pinning  of Intel(R) MPI Library Developer Reference for Linux* OS (2021.2), there are these sentences:
If you do not specify values for any
process
 pinning environment variables, the default settings below are used. For details about these settings, see Environment Variables and Interoperability with OpenMP API.
I_MPI_PIN=on
I_MPI_PIN_MODE=pm
I_MPI_PIN_RESPECT_CPUSET=on
I_MPI_PIN_RESPECT_HCA=on
I_MPI_PIN_CELL=unit
I_MPI_PIN_DOMAIN=auto:compact
I_MPI_PIN_ORDER=compact
But when I set this variable, I get 'I_MPI_PIN_MODE variable has been removed from the product, its value is ignored'. The variable is described in the lastest document.
Where could I find the lastest document which is compatible with oneapi 2021.2 I'm using ?
SantoshY_Intel
Thanks for reporting to us.
We are investigating your issue and we will get back to you soon with an update.
You can get the details of all available flags using the "impi_info -a" command. And if you want the details of a specific flag, then you can use the command "impi_info -v <flag>".
Thanks & Regards,
Santosh
Klaus-Dieter_O_Intel
You are right, the document https://software.intel.com/content/www/us/en/develop/articles/tuning-the-intel-mpi-library-advanced-... is outdated. Sorry for the inconvenience, we are working on an update.
Since Intel MPI 2019 the I_MPI_EAGER_THRESHOLD is not supported. Intel MPI now relies on the libfabric layer. Please use the environment variables from libfabric described in article https://software.intel.com/content/www/us/en/develop/articles/intel-mpi-library-2019-over-libfabric..... This information will be added to the next Release Notes.
The following information was added to the Intel MPI Release Notes
https://software.intel.com/content/www/us/en/develop/articles/intel-mpi-library-release-notes-linux....
* Since Intel(R) MPI Library version 2019 environment variable I_MPI_EAGER_THRESHOLD is not supported, please use corresponding libfabric controls instead
And the outdated information about the variable I_MPI_PIN_MODE was removed from
https://software.intel.com/content/www/us/en/develop/documentation/mpi-developer-reference-linux/top...
