Community
cancel
Showing results for
Search instead for
Did you mean:
Intel MPI failure from MPI_SEND MPI_RECEIVE
HI, James,
I am testing Intel MPI on my computer. I do not know why the following MPI sample codes failed to run. after I made a minor revision on stoping message from sending from process 0 to iteself, then everything works well. Why is process 0 not allowed to send message to itself in Intel MPI and then receive it by itslef? I look forward to hearing from you. Thanks.
Dingjun
Please the original sample codes:
program vector
   include 'mpif.h'
   integer SIZE
   parameter(SIZE=4)
   integer numtasks, rank, source, dest, tag, i,  ierr
   real*4 a(0:SIZE-1,0:SIZE-1), b(0:SIZE-1)
   integer stat(MPI_STATUS_SIZE), rowtype
C  Fortran stores this array in column major order
   data a  /1.0, 2.0, 3.0, 4.0,
  &         5.0, 6.0, 7.0, 8.0,
  &         9.0, 10.0, 11.0, 12.0,
  &         13.0, 14.0, 15.0, 16.0 /
   call MPI_INIT(ierr)
   call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
   call MPI_COMM_SIZE(MPI_COMM_WORLD, numtasks, ierr)
   call MPI_TYPE_VECTOR(SIZE, 1, SIZE, MPI_REAL, rowtype, ierr)
   call MPI_TYPE_COMMIT(rowtype, ierr)
   tag = 1
   if (numtasks .eq. SIZE) then
      if (rank .eq. 0) then
         do 10 i=0, numtasks-1
         call MPI_SEND(a(i,0), 1, rowtype, i, tag,
  &                    MPI_COMM_WORLD, ierr)
10      continue
      endif
      source = 0
      call MPI_RECV(b, SIZE, MPI_REAL, source, tag,
  &                MPI_COMM_WORLD, stat, ierr)
      print *, 'rank= ',rank,' b= ',b
   else
      print *, 'Must specify',SIZE,' processors.  Terminating.'
   endif
   call MPI_TYPE_FREE(rowtype, ierr)
   call MPI_FINALIZE(ierr)
   end
The minor revisions are made for the above sample codes and please see the following codes:
program vector
include 'mpif.h'
integer SIZE
parameter(SIZE=4)
integer numtasks, rank, source, dest, tag, i,j, ierr
integer stat(MPI_STATUS_SIZE), rowtype,avalue
! data a /1.0, 2.0, 3.0, 4.0,
! & 5.0, 6.0, 7.0, 8.0,
! & 9.0, 10.0, 11.0, 12.0,
! & 13.0, 14.0, 15.0, 16.0 /
avalue=0
do i=0,3
doj=0,3
avalue= avalue+1
a(i,j)=avalue
end do
end do
call MPI_INIT(ierr)
callMPI_TYPE_COMMIT(rowtype, ierr)
tag = 1
do i=0,3
b(i)=a(0,i)
! array stored in column for Fortran
end do
print *,'rank= ',rank,' ', b
do i=1, numtasks-1
end do
endif
source = 0
if(rank.gt.0) then
endif
else
endif
end
James_T_Intel
Hi Dingjun,
MPI_Send is a blocking send.  What that means is that the call will not return until the data has been sent.  As such, if you send and receive in the same process, you will never reach the receive call.  If your program requires a send/receive within a process, you can instead use a non-blocking send or receive as the first call.  Consider MPI_Isend, MPI_Ibsend, MPI_Issend, MPI_Irsend, and MPI_Irecv.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
