Intel® oneAPI HPC Toolkit
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
1828 Discussions
LAPACKE - dgetri and dgetrf for large matrix - avoid std::bad_alloc' error
chris6
In C++, I need a function which enables the inversion on large matrixes (at the maximum, I need to inverse 120,000 x 120,000 size matrix).
I am trying with the workstation at work to perform this with LAPACKE dgetri and dgetrf routines with Intel OneAPI framework.
The workstation has 1TB of RAM and 2 GPU cards RTX A6000 of 48GB for each one.
Currently, the maximum that I can invert is roughly a matrix of 50,000 x 50,000. Over this size, the 1TB RAM if full and I get the following error :
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
Command terminated by signal 6
Here the implemented function which inverses a matrix :
// Inversion Matrix : passing Matrixes by Reference
void matrix_inverse_lapack(vector<vector<double>> const &F_matrix, vector<vector<double>> &F_output) {
  // Index for loop and arrays
  int i, j, ip, idx;
  // Size of F_matrix
  int N = F_matrix.size();
  cout << "m = " << N << endl;
  int *IPIV = new int[N];
  // Statement of main array to inverse
  double *arr = new double[N*N];
  // Statement of returned matrix of size N
  //vector<vector<double> > F_final(N, vector<double>(N));
  // Output Diagonal block
  double *diag = new double[N];
  //#pragma omp parallel for num_threads(n_threads)
  for (i = 0; i<N; i++){
    for (j = 0; j<N; j++){
      idx = i*N + j;
      arr[idx] = F_matrix[i][j];
  // LAPACKE routines
  int info1 = LAPACKE_dgetrf(LAPACK_ROW_MAJOR, N, N, arr, N, IPIV);
  int info2 = LAPACKE_dgetri(LAPACK_ROW_MAJOR, N, arr, N, IPIV);
      idx = i*N + j;
      F_output[i][j] = arr[idx];
  delete[] IPIV;
  delete[] arr;
Is there a workaround with LAPACKE to be able to invert a 120,000 x 120,000 matrix without having a bad alloc error, even if the RAM of workstation has 1TB?
PS: I have also tried to use MAGMA for GPU cards but I am also limited to 40,000 x 40,000 matrix size for one GPU. I couldn't have for the moment found a way to combine the powerful in the same time of both GPU.
EDIT :
Is there a way to pass by reference the F_matrix input variable as arguments for LAPACKE dgetrf and degetri? I remind that F_matrix has a type vector<vector<double>>.
Thanks in advance for your help.
Best regards
Gennady_F_Intel
Christophe,
please try to link against MKL ILP64 API. Check what MKL Linker Adviser (https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl/link-line-advisor.html) suggests to link with. In that case, don't forget to change all integers into your code as MKL_INT types.
the second way to solve such huge problems - use the distributed versions of these routines ( p?getri and p?getrf correspondingly) to run across many computing nodes. But in that case, You have to change the int datatypes to MKL_INT as well and link against ILP64 mkl's libraries as well.
-Gennady
chris6
Hello Gennady,
Thanks for your quick answer.
Your first option didn't avoid to get 1TB RAM to be full and error bad alloc .
For your second suggestion, there a few examples on the web for pdgetri and pdgetf routines.
How to pass from :
// LAPACKE routines
MKL_INT info1 = LAPACKE_dgetrf(LAPACK_ROW_MAJOR, N, N, arr, N, IPIV);
MKL_INT info2 = LAPACKE_dgetri(LAPACK_ROW_MAJOR, N, arr, N, IPIV);
to pdgetri and pdgetrf ?
If someone could help me to implement these new routines for me, I didn't understand all the required arguments.
Best regards, chris
Gennady_F_Intel
MKL contains the Fortran API of PDGETRF routine example. You may find out this example in MKKLROOT/examples/scalapackf directory. There is no example of p?getri routine available.
Meantime, originally I wrongly estimate the memory allocation sizes for 120k x 120 k matrixes.
Actually, the allocated size of double-precision 120kx120k matrix == size * size* sizeof(double) ~ 110 Gb. You could see its feet with your 1TB RAM .
I made the trivial dgetrf example ( see attached),
Built it by using -DML_ILP64 compiler option and linked against ILP64 version of mkl libraries:
icc -DMKL_ILP64 -I/opt/intel/oneapi/mkl/2021.4.0/include test_getrf_huge.cpp \
-Wl,--start-group \
/opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_intel_ilp64.a \
/opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_intel_thread.a \
/opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_core.a \
-Wl,--end-group -liomp5 -lpthread -lm -ldl
Running this executable on the local AVX-512 based CPU with 256 Gb of RAM, plus MKL_VERBOSE mode, I see the getrf passed with Ok result. The execution time = 426 sec.
$ ./a.out 120000
MKL_VERBOSE oneMKL 2021.0 Update 4 Product build 20210904 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) with support of Intel(R) Deep Learning Boost (Intel(R) DL Boost), EVEX-encoded AES and Carry-Less Multiplication Quadword instructions, Lnx 2.40GHz ilp64 intel_thread
MKL_VERBOSE DGETRF(120000,120000,0x150c472aa080,120000,0x1541ed9a9080,0) 426.99s CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:72
...LAPACKE_dgetrf returns 0, SIZE = 120000
-Gennady
Gennady_F_Intel
I attached the test I used.
chris6
Hello Gennady !
Your test code worked fine on the worstation. But runtime is relatively long compared to you (roughly 1800s). I have a processor AMD EPYC 64 cores (128 threads).
During the execution, I can see the 64 threads launched by the code (OMP_NUM_THREADS).
But for my code, RAM becomes quickly full and reach the 1TB, and one gets error "terminate called after throwing an instance of 'std::bad_alloc' ".
I think this is due to the fact I am using in other parts of the code 120k x 120k.
Tha's why I would like to pass to scaLAPACK, since I think a distributed computation is necessary in my case.
But as you mentioned it, there is only an example in Fortran, not C++.
Do you know by chance other sources or test codes for "pdgetrf" combined with "pdgetri" to carry out a 120k x 120k matrix inversion.
Here my last code with your suggestions :
// Passing Matrixes by Reference
MKL_INT i, j, ip, idx;
// Size of F_matrix
MKL_INT N = F_matrix.size();
//MKL_INT *IPIV = new MKL_INT[N];
MKL_INT *IPIV = (MKL_INT*)mkl_calloc( N, sizeof(MKL_INT), 64);
double *arr = (double*) mkl_calloc( N*N, sizeof(double), 64);
idx = i*N + j;
Compiled with intel.make :
CXX = icpc -std=c++11 -O3 -xHost -DMKL_ILP64
CXXFLAGS = -Wall -c -I${MKLROOT}/include -I/opt/intel/oneapi/compiler/latest/linux/compiler/include -qopenmp -qmkl=parallel
LDFLAGS = -L${MKLROOT}/lib -Wl,-rpath,${MKLROOT}/lib -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -ldl
SOURCES = main_intel.cpp XSAF_C_intel.cpp
EXECUTABLE = main_intel.exe
Any clues or suggestions ?
Gennady_F_Intel
<< that's mean the problem is outside of MKLs calls and therefore you could somehow redesign the memory consumption of this application.
>> That's why I would like to pass to ScaLAPACK, since I think a distributed computation is necessary in my case.
<< I have only two suggestions: 1/ the C code of pdgetrf will look very similar to Fortran counterpart. A similar is true wrt pgetri routine. 2/ you might try to search this forum to see such kinds of examples.
Gennady_F_Intel
The thread is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
