Intel® oneAPI HPC Toolkit
1963 Discussions
Loopback traffic with libfabrics-verbs
eburrows
I'm seeing a ton of loopback traffic on my IntelMPI-openfabrics installation using a Broadcom RoCE NIC, even with single-host tests.
I'm setting the fabric, provider, and device parameters as:
 -genv I_MPI_FABRICS=shm:ofi  -genv FI_PROVIDER=verbs -genv FI_VERBS_DEVICE_NAME=bnxt_re0
When I run a single-node test with I_MPI_FABRICS=shm, the job runs fine, but when shm:ofi is used, it seems to send all traffic through the RNIC. I believe this is causing congestion in multi-host tests. Any advice for enabling shared-memory communications for intra-node communications, and verbs for inter-node communications?
Intel MPI Version: Intel(R) MPI Library, Version 2019 Update 8 Build 20200624 (id: 4f16ad915)
ShivaniK_Intel
 Can you please elaborate more on this issue?
 Does this affect the performance of your application? If yes, can you please provide the performance details and steps to reproduce?
The environment variables you have been using are correct but for better practice, we recommend you use the command as below
I_MPI_FABRICS=shm:ofi FI_PROVIDER=verbs FI_VERBS_DEVICE_NAME=bnxt_re0 mpirun -np <no. of processes> ./a.out
For more details, you can refer to the below link.
https://software.intel.com/content/www/us/en/develop/articles/intel-mpi-library-2019-over-libfabric....
Thanks & Regards
Shivani
eburrows
Hi Shivani,
> Can you please elaborate more on this issue? Does this affect the performance of your application? If yes, can you please provide the performance details and steps to reproduce?
This is the Ansys Fluent tool, running the "Aircraftwing" benchmark.  Performance is OK, but about 20% of the time, the job hangs on startup, with each thread busy-waiting over poll_cq() and writes to /dev/infiniband/rdma_cm.
I do not expect to see local traffic in the NIC counters, and I suspect this is causing congestion and possible flooding of RDMACM.  I understand MPI_THREAD_SPLIT mode is intended to work this way, but I do not believe I am running the release_mt or debug_mt platforms required for THREAD_SPLIT.
Thanks, I changed to this model of invoking mpirun, but as expected, did not see any change in behavior.
James_T_Intel
In some versions, ANSYS does link with release_mt. ANSYS usually forces linkage with the specific version they ship, please check if this is the release_mt or release path in your version.
James_T_Intel
I apologize for the delay in updating this thread. In phone discussions, this appears to be resolved by using Intel® MPI Library 2021.3 with I_MPI_OFI_PROVIDER=psm3.
I will be closing this thread for Intel support. Any further replies will be considered community only.
