Intel® MPI Library
MPI_BARRIER not finishing
Jesper_Carlson
Hi.
I have a problem with a "fairly simple" program regarding a non finishing MPI_BARRIER using 7 nodes on 2 computers.
I have modified the test.f90 program supplied with MPI 4.0.2.005 to cause the problemand I have added the file as an attachment here.
The program is compiled through Visual Studio 2008 withIntel ComposerXE-2011 version 12.0.4.196 Build 20110427
The setup:
1 laptop 2 corerunning 1 mpi thread
1 computer 12 corerunning 6 mpi threads
executing:
mpiexec -hosts 2 host1 1 host 2 6 "MPI Test.exe"
Using the 2 hosts with their max number of cores or with only 1 core works.
From the fortran and the output can you give any hints as to why the program does not finish?
Best Regards
Jesper Carlson
Dmitry_K_Intel2
Hi Jesper,
According to the Release Notes there is a requirement for a cluster to be homogeneous.
- The Intel MPI Library does not support heterogeneous clusters of mixed architectures and/or operating environments.
Sometimes it's even difficult to run applications on a cluster with mixed OSes like: Windows XP and Windows Server, Windows 7 and Windows Server.
You are using absolutely different nodes and it may lead to unpredictable results. Of cause I cannot reproduce the issue on our servers.
You may try to set fast fabric explicitly (-env I_MPI_FABRICS shm:tcp). Also you may try to add '-env I_MPI_PLATFORM 0', but I cannot guarantee that it will work.
BTW to understand what's going wrong you can use I_MPI_DEBUG environment variable with levels from 5 to 1000. (-env I_MPI_DEBUG 5)
Regards!
Dmitry
michel_lestrade
Hi Dmitry,
Can you clarify this part:
Does this mean all the machines have to have the same CPU model (e.g. i7), brand (Intel/AMD) or just that they all have to be x64-based ?
Jesper_Carlson
HI Dmitry
Ah yes i see the error in not using a homogeneous setup, in other situations we do indeed stick to identical setups.
Using '-env I_MPI_PLATFORM 0' actually did allow the program to finish correctly
I guess its a flag for remembering the requirements :-)
Thank you for your help and time
Jesper Carlson
Dmitry_K_Intel2
Actually, with latest versions of the Intel MPI Library you can use '-env I_MPI_PLATFORM auto'. In this case the library itself tries to identify the best settings for the existing nodes. Start-up may be a bit slower but at least it's much better than SegFault or something like that.
Regards!
Dmitry
