Community
cancel
Showing results for
Search instead for
Did you mean:
Qinghua_W_
MPI_Info_set crashes
Here is a small section of my test code
use mpi
  call mpi_init(info)
  comm = mpi_comm_world
  call MPI_COMM_SIZE(comm, nproc, info)
  call MPI_COMM_RANK(comm, node_me, info)
  len0 = 300
  len1 = int8(len0)*10*100
  size = len1
  disp_unit = 8
  size = size*disp_unit
  call MPI_Info_create(info_nc,ierr)
  call MPI_Info_set(info_nc, "alloc_shared_noncontig" , ".true." ,ierr)
  call MPI_Win_allocate_shared(size, disp_unit, info_nc, &
                             comm, baseptr, win,ierr)
It always crashes when calling subroutine MPI_Info_set with a message as follows
Unhandled exception at 0x000007FEE07FDA6E (impi.dll)
I used the lastest intel  fortran compiler 17.0 and intel mpi library 2017 (2017.1.143). It was tested on MS Windows 7.
Qinghua
James_T_Intel
Can you provide a full reproducer?  When I put what you have provided into a small code, it is working correctly.
