- Email to a Friend
Hello.
I use BLACS and ScaLapack to inverse dense matrix.
And I got some troubles.
I set up nprow and npcol for block-cyclic distribution for example 2, 2.
and run this routine
The stange thing is that after Cblacs_gridinfo(..) nprow is changed as 0.
Whyis it changed?
Because it is changed to 0, numroc(..) called after that generates error.
Could you give me some ideas?
Thanks in advance.
ps. Is there another method to inverse matrix without BLACS?
[cpp]nprow = 2; npcol=2; Cblacs_get(0,0,&ictxt); Cblacs_gridinit(&ictxt,"R",nprow,npcol); Cblacs_gridinfo(ictxt,&nprow,&npcol,&myrow,&mycol); [/cpp]
Whyis it changed?
Thanks in advance.
- Email to a Friend
Quoting - phaser75
Hello.
Whyis it changed?
Thanks in advance.
[cpp]nprow = 2;
npcol=2;
[/cpp]
Whyis it changed?
Thanks in advance.
Hi phaser75,
I'm afraid that there are no specialists in this thread who could help you with BLACS. This thread is mainly dedicated to Intel MPI Library. You could try Lapack forum first: http://icl.cs.utk.edu/lapack-forum/
Please compare your appplication with an example here: http://www.netlib.org/lapack-dev/old/examples/test_pdgesvd.c.html
Best wishes,
Dmitry
Topic Options
