If I use Intel MPI update 7 in a Slurm configuration on two cores on two separate nodes, I get a SIGFPE here (according to gdb on the generated core file):
#0 0x00000000004436ed in ipl_create_domains (pi=0x0, scale=4786482) at ../../../../../src/pm/i_hydra/../../intel/ipl/include/../src/ipl_service.c:2240
This happens only with mpirun / mpiexec.hydra using e.g. "mpirun -n 2 ./test"
I know of 3 workarounds, any of which will let me run this successfully, but I thought maybe you or others should know about this crash:
1. Set I_MPI_PMI_LIBRARY=libpmi2.so and use "srun -n 2 ./test" (with Slurm configured to use pmi2).
2. Use I_MPI_HYDRA_TOPOLIB=ipl
3. Use the "legacy" mpiexec.hydra.
- Tags:
- Cluster Computing
- General Support
- Intel® Cluster Ready
- Message Passing Interface (MPI)
- Parallel Computing
Some more details:
OS: CentOS 7.7, Linux blg8616.int.ets1.calculquebec.ca 3.10.0-1062.12.1.el7.x86_64 #1 SMP Tue Feb 4 23:02:59 UTC 2020 x86_64 Intel(R) Xeon(R) Gold 6148 CPU @ 2.40GHz GenuineIntel GNU/Linux
If I run (from "mpiicc ${I_MPI_ROOT}/test/test.c -g -o test") with "I_MPI_HYDRA_TOPOLIB=ipl" I get this:
[oldeman@blg8616 test]$ I_MPI_DEBUG=5 mpirun -n 2 ./test
[0] MPI startup(): libfabric version: 1.10.0a1-impi
[0] MPI startup(): libfabric provider: mlx
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 173711 blg8616.int.ets1.calculquebec.ca 37
[0] MPI startup(): 1 220728 blg8621.int.ets1.calculquebec.ca 29
[0] MPI startup(): I_MPI_CC=icc
[0] MPI startup(): I_MPI_CXX=icpc
[0] MPI startup(): I_MPI_FC=ifort
[0] MPI startup(): I_MPI_F90=ifort
[0] MPI startup(): I_MPI_F77=ifort
[0] MPI startup(): I_MPI_ROOT=/cvmfs/soft.computecanada.ca/easybuild/software/2019/avx2/Compiler/intel2020/intelmpi/2019.7.217
[0] MPI startup(): I_MPI_LINK=opt
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=ipl
[0] MPI startup(): I_MPI_HYDRA_BOOTSTRAP=slurm
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_DEBUG=5
Hello world: rank 0 of 2 running on blg8616.int.ets1.calculquebec.ca
Hello world: rank 1 of 2 running on blg8621.int.ets1.calculquebec.ca
but without that set, it gives me (and also with just "hostname"):
srun: error: blg8621: task 1: Floating point exception (core dumped)
srun: error: blg8616: task 0: Floating point exception (core dumped)
[mpiexec@blg8616.int.ets1.calculquebec.ca] wait_proxies_to_terminate (../../../../../src/pm/i_hydra/mpiexec/intel/i_mpiexec.c:528): downstream from host blg8616 exited with status 136
[mpiexec@blg8616.int.ets1.calculquebec.ca] main (../../../../../src/pm/i_hydra/mpiexec/mpiexec.c:2114): assert (exitcodes != NULL) failed
Hi Bart,
We will investigate this issue further and will get back to you soon.
Prasanth
Hi Bart,
Intel MPI Library 2019 U8 has just been released. Could you please rerun your experiments with mpiexec.hydra and report your findings, please?
Amar
Hi Bart,
Having not received your response for over a month, I am going ahead and closing this thread. Whenever, Intel MPI Library's native process manager is not used, we recommend to set the PMI library explicitly, using the I_MPI_PMI_LIBRARY environment variable.
For more details, please refer to the following links -
[2] https://slurm.schedmd.com/mpi_guide.html
This issue will be treated as resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Amar
