Intel® oneAPI HPC Toolkit
1987 Discussions
Unable to get windows domain authentication working (-delegate) with a network executable.
jefffaust
The commands below demonstrate the problem I am seeing. The -delegate option works for a local executable, but not one on a network drive.
# Register to use password authentication
C:\Users\local>mpiexec -register
account (domain\user) [COMPANY\local]:
password:
confirm password:
Password encrypted into the Registry.
# Demonstrate with local executable
C:\Users\local>mpiexec -ppn 1 -hosts local-computer,cluster-01 hostname.exe
cluster-01
local-computer
# Demonstrate mpi use with network drive (hostname.exe is copied from c:\windows\system32)
C:\Users\local>mpiexec -ppn 1 -hosts local-computer,cluster-01 \\network\hostname.exe
local-computer
cluster-01
# Unregister password authentication
C:\Users\local>mpiexec -unregister
Account and password removed from the Registry.
# Fails as expected
User credentials needed to launch processes: ^C
# Domain-based authentication works
C:\Users\local>mpiexec -delegate -ppn 1 -hosts local-computer,cluster-01 hostname.exe
cluster-01
local-computer
# But not from a network drive
C:\Users\local>mpiexec -delegate -ppn 1 -hosts local-computer,cluster-01 \\network\hostname.exe
local-computer
[-1:9156]ERROR:execvp error on file: \\network\hostname.exe, Access is denied.
PrasanthD_intel
Hi Jeffrey,
The right team is handling the ticket. They will update you as soon as the solution/fix is available. We are a different team so we may not be able to post the updates here.
Prasanth
PrasanthD_intel
Hi Jeffrey,
Could you tell us on which node you are running, you can get that by running whoami command.
Also are local-computer,cluster-01 part of the network drive(\\network\)? or the \\network is a third system?
Prasanth
jefffaust
Hi Prasanth,
I'm running from local-computer. \\network is a filer UNC path on the same network as the other two computers. There are no firewalls.
-Jeff
PrasanthD_intel
Hi Jeffrey,
If all systems belong to the same domain and still -delegate is not working, this seems to be an issue from our side.
We are transferring this to Internal team.
Prasanth
jefffaust
Thanks Prasanth. After posting here, I did open a service request. It is #04790385.
-Jeff
PrasanthD_intel
Hi Jeffrey,
Since you have raised a ticket, can we close the case here?
--Prasanth
jefffaust
Hi Prasanth,
I think it would be fair to post the solution here as well, when it's available.
-Jeff
PrasanthD_intel
Hi Jeffrey,
Prasanth
PrasanthD_intel
Hi Jeffrey,
Thanks for confirming. We will be closing this thread.
Please raise a new thread for any additional support in future.
Prasanth
