The commands below demonstrate the problem I am seeing. The -delegate option works for a local executable, but not one on a network drive.
# Register to use password authentication
C:\Users\local>mpiexec -register
account (domain\user) [COMPANY\local]:
password:
confirm password:
Password encrypted into the Registry.
# Demonstrate with local executable
C:\Users\local>mpiexec -ppn 1 -hosts local-computer,cluster-01 hostname.exe
cluster-01
local-computer
# Demonstrate mpi use with network drive (hostname.exe is copied from c:\windows\system32)
C:\Users\local>mpiexec -ppn 1 -hosts local-computer,cluster-01 \\network\hostname.exe
local-computer
cluster-01
# Unregister password authentication
C:\Users\local>mpiexec -unregister
Account and password removed from the Registry.
# Fails as expected
User credentials needed to launch processes: ^C
# Domain-based authentication works
C:\Users\local>mpiexec -delegate -ppn 1 -hosts local-computer,cluster-01 hostname.exe
cluster-01
local-computer
# But not from a network drive
C:\Users\local>mpiexec -delegate -ppn 1 -hosts local-computer,cluster-01 \\network\hostname.exe
local-computer
[-1:9156]ERROR:execvp error on file: \\network\hostname.exe, Access is denied.
Hi Jeffrey,
The right team is handling the ticket. They will update you as soon as the solution/fix is available. We are a different team so we may not be able to post the updates here.
Prasanth
Hi Jeffrey,
Could you tell us on which node you are running, you can get that by running whoami command.
Also are local-computer,cluster-01 part of the network drive(\\network\)? or the \\network is a third system?
Prasanth
Hi Prasanth,
I'm running from local-computer. \\network is a filer UNC path on the same network as the other two computers. There are no firewalls.
-Jeff
Hi Jeffrey,
If all systems belong to the same domain and still -delegate is not working, this seems to be an issue from our side.
We are transferring this to Internal team.
Prasanth
Thanks Prasanth. After posting here, I did open a service request. It is #04790385.
-Jeff
Hi Jeffrey,
Since you have raised a ticket, can we close the case here?
--Prasanth
Hi Prasanth,
I think it would be fair to post the solution here as well, when it's available.
-Jeff
Hi Jeffrey,
Prasanth
Hi Jeffrey,
Thanks for confirming. We will be closing this thread.
Please raise a new thread for any additional support in future.
Prasanth
