Intel® oneAPI HPC Toolkit
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
debugging hung up mpi ranks
psing51
I am working with an mpi application which hangs up after ~1 hour of run.
Here is the example of application launch -
mpirun -np 32 -ppn 4  ./wrf.exe
Currently, I am not sure about the line of code where the application hangs up so that i can setup few breakpoints in advance. Also, the compute nodes don't have X11. As the simulation gets stuck after ~1 hour of run and source codebase is very large, it is very difficult to debug this issue with
mpirun -gdb -np 32 -ppn 4  ./wrf.exe
I have a debug version (-g) of the executables. Is there a way through which i can attach to the hanged up/stuck MPI ranks/processes and check the current source code location of each rank ?
Could you please share the sequence of commands to be executed to analyze the problematic source code location -if  possible?
ShivaniK_Intel
Could you please let us know the version of Intel mpi you have been using and OS details?
Could you also provide the output using the below command?
I_MPI_DEBUG=30 mpirun -check-mpi -np 32 -ppn 4 ./wrf.exe
Thanks & Regards
Shivani
ShivaniK_Intel
As we didn't hear back from you, Could you please provide the details that have been asked in my previous post so that we can investigate more on your issue?
Thanks & Regards
Shivani
ShivaniK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Shivani
