Intel® MPI Library
it is not using two IB’s and the stats.ipm file is empty
soni__deepak
i tried this one CFX job but it is not using two IB’s , i used following setting,
export I_MPI_TMPDIR=/scratch/pwc/asd0392/tmp
export I_MPI_DEBUG=5
export I_MPI_FABRICS=shm:ofa
export I_MPI_FALLBACK=0
export I_MPI_OFA_NUM_ADAPTERS=2
export I_MPI_OFA_NUM_PORTS=1
export I_MPI_STATS=ipm
export I_MPI_STATS_FILE=stats.ipm
export I_MPI_HYDRA_BOOTSTRAP=lsf
export I_MPI_HYDRA_BRANCH_COUNT=${numhost}
export I_MPI_LSF_USE_COLLECTIVE_LAUNCH=1
export I_MPI_MPIRUN_CLEANUP=yes
export I_MPI_HYDRA_CLEANUP=yes
how to use infiniband dual-rail ?
regards
deepak
PrasanthD_intel
 Could you please provide which version of IMPI you are using.
Prasanth
soni__deepak
Thanks Prasanth for reply.
please find the version information
Intel(R) MPI Library for Linux* OS, Version 4.1 Update 3 Build 20140226
i have attached a log for it . may be get some more details
just adding one more query related to this issue
any specific framework for osu-benchmark in intel cluster checker ?
regards
deepak
Michael_Intel
Hi Deepak,
The Intel MPI 4.1 Version is quite outdated and not supported anymore.
In the latest Intel MPI 2019 update 6 library, we have a new OFI provider for InfiniBand called MLX, that will also be selected out of box. This provider will also run on multi-rail installations with the default configuration.
Michael
