Community
cancel
Showing results for
Search instead for
Did you mean:
mpiexec run on different os
I am developing a program using mpi routine with intel parallel studio xe 2013
After compile, I want to distribute the developed software to other people who dont have cluster studio.
Therefore, I copied only mpiexec, smpd and impi.dll to the my other test computers.
First, the mpiexec ran successfully on the each computer with multi cores.
However, when i try to run multi hosts that have different os. There was problem.
 One is Windows server 2012 and the other is windows 7
like : mpiexec -hosts 2 host1 host2 ****.exe   filename
it said : abort : unable to connect to host2
is it impossible to use multi hosts with different o/s
