Intel® oneAPI HPC Toolkit
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
1845 Discussions
mpitune: Error in thread 'MTWTN_0': 'NoneType' object has no attribute 'group'
Pak_Lui
Hi, I tried to run mpitune for analyzing the Bcast algorithm only but I got this error. If I take it out the "--os" option, I still see the same 'NoneType' object has no attribute 'group' message that shows up on some of the tests. Why is that?
$ mpitune -of ./asdf.cfg -verbose -fl shm:ofa -hf ~/hostfile --app \\"mpiexec -n 256 ./asdf.exe\\" --os I_MPI_ADJUST_BCAST
06'Jul'12 18:12:21 | MTWTN_0 : Chosen default
06'Jul'12 18:12:21 | MTWTN_0 : Obtaining default values in critical mode...
06'Jul'12 18:12:24 | MTWTN_0 : Complete. Default values is: 7:0-2147483647
06'Jul'12 18:12:24 | MTWTN_0 : Default option value is: 7:0-2147483647
06'Jul'12 18:12:24 | MTWTN_0 : Length of algorithms list is 0. Default value for option will be used.
06'Jul'12 18:12:24 DBG | Load environment from file (as dictionary): ./asdf.cfg
06'Jul'12 18:12:24 ERR | Error in thread 'MTWTN_0': 'NoneType' object has no attribute 'group'
06'Jul'12 18:12:24 CER | A critical error has occurred!
Details:
Type : exceptions.AttributeError
Value : 'NoneType' object has no attribute 'group'
Dmitry_K_Intel2
Hi Lui,
Could you please attach 'asdf.cfg' to the reply. It seems to me that something wrong with regexp in this file.
Regards!
---Dmitry
