Dear All,
I have successfully installed parallel_studio_xe_2017_update1 in CentOS 7. Installed package is working good. However, I am getting the error when I source it from my .tcshrc file. Please suggest what could be an issue. My default SHELL is tcsh. Please see the error when I login to the terminal and source it through terminal. Please help.
Raju
Last login: Fri Feb 10 10:32:49 2017 from 146.114.195.2
Intel(R) Parallel Studio XE 2017 Update 1 for Linux*
Copyright (C) 2009-2016 Intel Corporation. All rights reserved.
mpsvars.csh: ERROR: Could not find correct folders structure.
[XXXX@air ~]$ source /opt/intel/parallel_studio_xe_2017.1.043/bin/psxevars.csh
[XXXX@air ~]$
Hi Raju,
The mpsvars.csh is for sourcing the ITAC, which can be located under the itac directory: /opt/intel/itac/2017.1.024/intel64/bin/mpsvars.csh.
You can probably check if the mpsvars.csh in .tcshrc has the wrong settings.
Thank you
Zhuowei
