Hello Intel
I have found a strange bug in MVAPICH2 using IFORT. The behavior is very strange indeed - it seems to be related to how ifort deals with passing pointers to the MVAPICH FORTRAN 90 INTERFACE.
The MPI call returns successfully, but later calls to a dummy subroutine cause a sigsev.
Please look at the following code - sorry if the post caused formatting issues, I don't have permission to attach the file.
! TEST CODE TO FOR POSSIBLE BUG IN MVAPICH2 COMPILED ON IFORT
! WRITEN BY: DAVID STUEBE
! DATE: JAN 23, 2008
! COMPILE WITH: mpif90 -xP mpi_prog.f90 -o xtest
! KNOWN BEHAVIOR:
! PASSING A NONE CONTIGUOUS POINTER TO MPI_BCAST CAUSES FAILURE OF
! SUBROUTINES USING MULTI DIMENSIONAL EXPLICT SHAPE ARRAYS WITHOUT AN INTERFACE -
! EVEN THOUGH THE MPI_BCAST COMPLETES SUCCESUFULLY, RETURNING VALID DATA.
! COMMENTS:
! I REALIZE PASSING NON CONTIGUOUS POINTERS IS DANGEROUS - SHAME ON
! ME FOR MAKING THAT MISTAKE. HOWEVER, IT SHOULD EITHER WORK OR NOT.
! RETURNING SUCCESSFULLY BUT CAUSING INTERFACE ERRORS LATER IS
! EXTREMELY DIFFICULT TO DEBUG!
! CONDITIONS FOR OCCURANCE:
! COMPILER MUST OPTIMIZE USING 'VECTORIZATION'
! ARRAY MUST BE 'LARGE' -SYSTEM DEPENDENT ?
! MUST BE RUN ON MORE THAN ONE NODE TO CAUSE CRASH...
! ie Running inside one SMP box does not crash.
! RUNNING UNDER MPD, ALL PROCESSES EXIT WHEN THEY HIT DUMMY2
! RUNNING UNDER MPIEXEC0.82 FOR PBS,
! ONLY SOME PROCESSES EXIT WHEN THEY HIT DUMMY2
! ENVIRONMENTAL INFO:
! NODES: DELL 1850 3.0GHZ, 2GB RAM, INFINIBAND PCI-EX 4X
! SYSTEM: ROCKS 4.2
! gcc version 3.4.6 20060404 (Red Hat 3.4.6-3)
! IFORT/ICC:
! Intel Fortran Compiler for Intel EM64T-based applications,
! Version 9.1 Build 20061101 Package ID: l_fc_c_9.1.040
! MVAPICH2: mpif90 for mvapich2-1.0
! ./configure --prefix=/usr/local/share/mvapich2/1.0 --with-device=osu_ch3:mrail --with-rdma=vapi --with-pm=mpd --enable-f90 --enable-cxx --disable-romio --without-mpe
Module vars
USE MPI
implicit none
integer :: n,m,MYID,NPROCS
integer :: ipt
integer, allocatable, target :: data(:,:)
contains
subroutine alloc_vars
implicit none
integer Status
allocate(data(n,m),stat=status)
if (status /=0) then
write(ipt,*) "alloc ation error"
stop
end if
data = 0
end subroutine alloc_vars
SUBROUTINE INIT_MPI_ENV(ID,NP)
! INITIALIZE MPI ENVIRONMENT |
INTEGER, INTENT(OUT) :: ID,NP
INTEGER IERR
IERR=0
CALL MPI_INIT(IERR)
IF(IERR/=0) WRITE(*,*) "BAD MPI_INIT", ID
CALL MPI_COMM_RANK(MPI_COMM_WORLD,ID,IERR)
IF(IERR/=0) WRITE(*,*) "BAD MPI_COMM_RANK", ID
CALL MPI_COMM_SIZE(MPI_COMM_WORLD,NP,IERR)
IF(IERR/=0) WRITE(*,*) "BAD MPI_COMM_SIZE", ID
END SUBROUTINE INIT_MPI_ENV
SUBROUTINE PSHUTDOWN
INTEGER IERR
IERR=0
CALL MPI_FINALIZE(IERR)
if(ierr /=0) write(ipt,*) "BAD MPI_FINALIZE", MYID
close(IPT)
STOP
END SUBROUTINE PSHUTDOWN
SUBROUTINE CONTIGUOUS_WORKS
IMPLICIT NONE
INTEGER, pointer :: ptest(:,:)
INTEGER :: IERR, I,J
write(ipt,*) "START CONTIGUOUS:"
n=2000 ! Set size here
m=n+10
call alloc_vars
write(ipt,*) "ALLOCATED DATA"
ptest => data(1:N,1:N)
IF (MYID == 0) ptest=6
write(ipt,*) "Made POINTER"
call MPI_BCAST(ptest,N*N,MPI_INTEGER,0,MPI_COMM_WORLD,IERR)
IF(IERR /= 0) WRITE(IPT,*) "BAD BCAST", MYID
write(ipt,*) "BROADCAST Data; a value:",data(1,6)
DO I = 1,N
DO J = 1,N
if(data(I,J) /= 6) &
& write(ipt,*) "INCORRECT VALUE!", I,J,data(I,J)
END DO
&n bsp;
DO J = N+1,M
if(data(I,J) /= 0) &
END DO
END DO
! CALL THREE DIFFERENT EXAMPLES OF SUBROUTINES W/OUT AN ITERFACE
! THAT USE AN EXPLICIT SHAPE ARRAY
write(ipt,*) "CALLING DUMMY1"
CALL DUMMY1
write(ipt,*) "CALLING DUMMY2"
call Dummy2(m,n)
write(ipt,*) "CALLING DUMMY3"
call Dummy3
write(ipt,*) "FINISHED!"
END SUBROUTINE CONTIGUOUS_WORKS
SUBROUTINE NON_CONTIGUOUS_FAILS
IMPLICIT NONE
write(ipt,*) "START NON_CONTIGUOUS:"
m=200 ! Set size here
n=m+10
call alloc_vars
ptest => data(1:M,1:M)
! IF YOU CALL DUMMY2 HERE TOO, THEN EVERYTHING PASSES ???
! CALL DUMMY1 ! THIS ONE HAS NO EFFECT
! CALL DUMMY2 ! THIS ONE 'FIXES' THE BUG
call MPI_BCAST(ptest,M*M,MPI_INTEGER,0,MPI_COMM_WORLD,IERR)
DO I = 1,M
DO J = 1,M
if(data(J,I) /= 6) &
& write(ipt,*) "INCORRECT VALUE!",I,J,DATA(I,J)
END DO
DO J = M+1,N
if(data(J,I) /= 0) &
END DO
END DO
CALL DUMMY1
call Dummy2(m,n) ! SHOULD CRASH HERE!
call Dummy3
END SUBROUTINE NON_CONTIGUOUS_FAILS
End Module vars
Program main
USE vars
implicit none
CALL INIT_MPI_ENV(MYID,NPROCS)
ipt=myid+10
OPEN(ipt)
write(ipt,*) "Start memory test!"
CALL NON_CONTIGUOUS_FAILS
! CALL CONTIGUOUS_WORKS
write(ipt,*) "End memory test!"
CALL PSHUTDOWN
END Program main
! TWO DUMMY SUBROUTINE WITH EXPLICIT SHAPE ARRAYS
! DUMMY1 DECLARES A VECTOR - THIS ONE NEVER CAUSES FAILURE
! DUMMY2 DECLARES AN ARRAY - THIS ONE CAUSES FAILURE
SUBROUTINE DUMMY1
USE vars
implicit none
real, dimension(m) :: my_data
write(ipt,*) "m,n",m,n
write(ipt,*) "DUMMY 1", size(my_data)
END SUBROUTINE DUMMY1
SUBROUTINE DUMMY2(i,j)
USE vars
implicit none
INTEGER, INTENT(IN) ::i,j
real, dimension(i,j) :: my_data
write(ipt,*) "start: DUMMY 2", size(my_data)
END SUBROUTINE DUMMY2
SUBROUTINE DUMMY3
USE vars
implicit none
real, dimension(m,n) :: my_data
write(ipt,*) "start: DUMMY 3", size(my_data)
END SUBROUTINE DUMMY3
! KNOWN BEHAVIOR:
! COMMENTS:
! SYSTEM: ROCKS 4.2
! IFORT/ICC:
Module vars
USE MPI
implicit none
integer :: ipt
contains
implicit none
integer Status
stop
end if
data = 0
INTEGER IERR
IERR=0
CALL MPI_INIT(IERR)
INTEGER IERR
IERR=0
close(IPT)
STOP
IMPLICIT NONE
m=n+10
call alloc_vars
DO I = 1,N
DO J = 1,N
END DO
&n bsp;
DO J = N+1,M
END DO
END DO
CALL DUMMY1
call Dummy2(m,n)
call Dummy3
IMPLICIT NONE
n=m+10
call alloc_vars
DO I = 1,M
DO J = 1,M
END DO
DO J = M+1,N
END DO
END DO
CALL DUMMY1
call Dummy3
End Module vars
Program main
USE vars
implicit none
ipt=myid+10
OPEN(ipt)
CALL PSHUTDOWN
END Program main
SUBROUTINE DUMMY1
USE vars
implicit none
USE vars
implicit none
SUBROUTINE DUMMY3
USE vars
implicit none
Could youyou try the Intel MPI Library?
Andrey
Topic Options
