Intel® oneAPI HPC Toolkit
2001 Discussions
oneAPI 2021.1 compiler modulefiles isseue with Lmod (`is-avail` command does not exist)
dodo
I noticed that Lmod 8.4.19(latest version) do not support `is-avail` for now and it makes problem at  "/opt/intel/oneapi/modulefiles/compiler/2021.1.1`
if { [ is-avail $cmplr_root/linux/lib/oclfpga/modulefiles/oclfpga ] } {
     module load $cmplr_root/linux/lib/oclfpga/modulefiles/oclfpga
So I use `try-load` of Lmod:
module try-load $cmplr_root/linux/lib/oclfpga/modulefiles/oclfpga
However this requires tidious job for evey oneapi update in future.  Is there any better options for it?
PrasanthD_intel
Hi Lee,
I have checked the Lmod user guide 8.4.19 and I can see that is-avail has been mentioned as a functionality. I cannot find any reference of is-avail being removed.
But for the logic you are trying:
where you want to replace is-avail , i have a found a similar functionality in one of OneAPI files where they have used file exists instead of is-avail:
if { [file exists $modulefileroot/init_opencl] } {
  module load $modulefileroot/init_opencl
You can try this and see if it works for you. Let us know if you face any issues
Prasanth
dodo
Ah, by the way, I figured out default environment-modules of centos 7 is 3.2.10 which does not support `is-avail`. Since `is-avail` is supported from environment-modules  4.1.0 and above, I hope oneapi tutorial will clarify this point in future.
PrasanthD_intel
Hi Lee,
We haven't heard back from you.
Is the given alternative working for you? Let us know if you need any help
Prasanth
dodo
I have tested today, and it works! thank you.
PrasanthD_intel
Hi Lee,
Thanks for the confirmation.
I would pass your suggestion to the internal team.
As this issue has been resolved, we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Prasanth
